Hugh,
I'll take a shot at suggesting a prop based on a somewhat similar build I did for a customer - A slightly larger Mean Machine with a TP 4050 2200 KV motor on 4S. For blasting around I supplied Mitch with an Oct M545. You can see the results in the vid. Based on your slightly higher KV you might want to start out with an Oct M445 or similar and go from there - one minute runs & check temps.
Nice build
https://www.youtube.com/watch?v=m2rt6sH8jwE
