Results 1 to 7 of 7
Thread: info on 3674-B-2200kv
    Mar 2014
    IA
    165
    Default info on 3674-B-2200kv
    I now it's old but I never used it till now. Voltage range of 5.5 round connectors is what! Thank you!
    Apr 2017
    QL
    1,038
    so what are you wanting to know ? if its voltage , this motor is good for a 4s battery set up and a 180 amp esc.
    Mar 2014
    IA
    165
    Apr 2017
    QL
    1,038
    so what are you wanting to do , blow the motor up ? use 5 to 6 mm bullets and forget those high voltages as your only needing around 14 volts to run with this size motor. [ 4s battery pack ]
    Mar 2014
    IA
    165
    WOW! Your off as I was looking for the voltage 5.5 bullet connectors. Now on Aquastar esc starts of slow and then moves out real good. The directions say if this happens to check the system and most likely , the connectors are not allowing enough current to get to motor. Now I asked what is the voltage range of 5.5mm bullets. Moderator close said thread!!!!!!!!!!!!!!!!!
    7,279
    As best as i can figure out what is being asked here....i use 5.5 bullets on 10S with no issues.
    Apr 2017
    QL
    1,038
    yes its abit hard to understand what this guy is trying to say. maybe he means to say AMPS not Volts. you dont have any issues using 5.5 mm connectors as long as the soldering is good.
