Page 2 of 2 FirstFirst 12
Results 31 to 34 of 34
Thread: Water jacket stuck on motor...
  1. #31
    Nov 2008
    BC
    687
    you should never use oil just soap a lot of oils will swell rubber just a note. you have to remember not all O ring are made over here some are made over there and are not as good cheep rubber will swell up
  2. #32
    May 2016
    Mi
    82
    Take a dermal with a cut off wheel . Be carful and cut a line just threw the jacket from the front to rear. Then you can pry it off . If not cut a second cut and it should fall off. Sounds like u tried everything just cut it.
  3. #33
    Jun 2009
    ON
    71
    Quote Originally Posted by Bushmen77 View Post
    Thanks - it was definitely getting to that point. I sent it back to Steve at OSE to see if he can get it off, and otherwise cut it away and get a new one on for next season...
  4. #34
    Nov 2016
    MI
    44
    Thanks Chris hope your feeling better
    Gary
