Results 1 to 5 of 5
Thread: ESC Recommendations ?
    Aug 2019
    SC
    14
    Default ESC Recommendations ?
    It appears the Seaking 180A has some issues with cut off at full throttle based on feedback from my previous post. I'm running Venom batteries 5000mAh 50C 6s on a Traxxas M41, 42/63 prop, Leopard 4082 2200Kv motor. Programming the Seaking with lower LVC or auto calculate or changing timing from 0, 3.5, 7.5 11.5 doesnt remedy the problem. Any suggestions on a different ESC?
    Sep 2007
    2,778
    Removed and replied to other thread.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Mar 2008
    974
    The issue is your set up but I would run this one.
    https://www.offshoreelectrics.com/pr...d=hef-HBX1200L
    Aug 2019
    SC
    14
    Thanks, I appreciate the comment. Pretty fancy ESC, only question I have left is when I did turn off the LVC it worked?
    8,009
    This has been explained in another thread. That ESC has an internal design/build flaw concerning the LVC. Others have stated that turning the LVC off solves the problem....but you have to time your runs.
