Miss Geico 36 hits 92mph all stock with dasboata props!
  • MADRCER
    • Feb 2017
    • 751
    • MADRCER
      • Feb 2017
      • 751
      Miss Geico 36 hits 103mph on stock electronics!
      Got to love 60 degree February days.....New PB 103mph with my stock Geico 36 running Chris Hoffmann props (dasboata on here). Only if the wind would have cooperated....
      • dasboata
        • Dec 2010
        • 3152
        flying bro great way to start the season !!!
        • bhorowitz
          • Jun 2015
          • 109
          Madrcer,
          What do you use for the data logging?
          Bob
          • MADRCER
            • Feb 2017
            • 751
            Thanks Chris!
            Originally posted by bhorowitz
            Madrcer,
            Bob
            That log on this run was the Sky Rc GSM-015 GPS device. https://www.banggood.com/custlink/vD3mAhV1o0
            • Jamey
              • Apr 2015
              • 199
              Originally posted by MADRCER
              Thanks Chris!
              I was just looking at these. Can you click on a point on the logged trail and get the speed at that point? Or does it only give the peak for the run?
              • MADRCER
                • Feb 2017
                • 751
                Yes, Just run your mouse over any part of the line where the craft was at and it will display the speed it was going. It works the same as the Dynamite logger.
                • MADRCER
                  • Feb 2017
                  • 751
                  Worlds Fastest PRO BOAT (Miss Geico 36) 107.7mph!!
                  Worlds FASTEST PRO BOAT (Miss Geico 36) @ 107.7mph! All on STOCK ELECTRONICS with Chris Hoffmann (dasboata props).
                  • dasboata
                    • Dec 2010
                    • 3152
                    way to set the bar again Mark !!
                    • rearwheelin
                      • 1941
                      Those folk had a fishing story that day
                      --Albert Einstein
                      • zooma
                        Local club FE racer
                        • May 2014
                        • 651
                        Congrats MADRCER. Hey, how do you like that Canmore GPS for speed runs? Do you know how fast its refresh speed is? For example 1Hz is once a second, 10Hz is ten times a second.
                        Ron - The Villages, FL
                        • MADRCER
                          • Feb 2017
                          • 751
                          #27
                          108mph from the telementry
                          Thanks guys! Appreciate that!
                          Zooma I've had this GPS for a while and normally use it on my smaller crafts and trucks. Its an Awesome device and spot on in vehicle test against my others (the sky rc and dynamite can read a mph slow sometimes in vehicle test) I really like it. I'm pretty sure it's a 10hz refresh rate for it and my Garmins are the slower 1hz rate. It has a stronger antenna than any of my other GPS devices as well. It will get singal inside my home. The only downside is it isn't too user friendly but not too bad.
                          Well here is another video with the telemetry on screen.....watch it hit 108mph and still seem to be pulling mph until I let out of it.
                          • Hls1493
                            • Jul 2020
                            • 3
                            #28
                            Miss Geico 36 low speed porpoise
                            What drive hight are you guys running with the Geico 36?
                            My boat runs pretty good at 2.0mm up in rough water.
                            In glass conditions my boat wants to porpoise badly starting just after planning out.
                            I pulled the boat in, shoved the batteries forward (4 3s spectrum 5000 packs) and pushed the drives all the way down and it seemed to make no difference. Since then I have raised them to 2.5 mm up and have similar behavior.
                            I have them set to 3.125 mm up now which is still about 100/th of an inch lower at the back of the drive then the front of the drive at the transom, therefor still having a touch of negative prop angle. Will test this today.
                            Is it possible for these catamarans to porpoise due to the drives being to low?
                            Also, if I apply a little bit of left or right rudder when accelerating slowly from 1/4 throttle to 3/4 throttle the boat stays planted and from there I can let off of the rudder and run wide open with the boat running very stable, it does seem too wet though at that point. The props are completely stock. I do have a set or dasboata ?Geico? props on the way.
                              Dang bruh. See you been busy making things go fast!
                              • MADRCER
                                • Feb 2017
                                • 751
                                #30
                                Depends on what props, battery config i'm running, and water conditions. I ran the stock props a couple of times and it did 80mph with the stock settings.
                                Appreciate that Bro! We just trying to keep up...
