Results 1 to 6 of 6
Thread: Are 7.6v batts safe to use on Miss Geico29 v1 ?
    Apr 2011
    qr
    17
    Default Are 7.6v batts safe to use on Miss Geico29 v1 ?
    Hi there, I have an original v1 Miss Geico 29 and was wondering if I could use these new type of batteries. Would not want to risk frying anything...
    They are revolectrix packs with 7.6volts 5000mah and 70C discharge.
    Wonder if anyone has tried similar packs... thanks.
    Apr 2017
    QL
    1,038
    does this Geico 29 run on a 2s battery pack ?
    Apr 2011
    qr
    17
    Yes, it's the proboat. It uses two 2s battery packs.
    I had ordered standard 7.2 volt 2S battery packs but since they're out of stock I wondered If I could also use the higher voltage packs...
    Mar 2017
    VI
    371
    Yes those cells should be OK.
    Apr 2017
    QL
    1,038
    i see, 2 x 2 s in series = 4s x 5000mah pack.
    Apr 2011
    qr
    17
    Quote Originally Posted by Speed3 View Post
    Great to hear that. Hopefully, the improvement in speed will be noticeable.
    Yes, 4S indeed.
