I have these 2 neu 1515. 1650kv motors and some 4s lipos will these work for a twin mean machine fun run boat? And what props. Thanks in advance for any and all comments
Geno, I think that sounds like a good setup. You’d be running bigger props with the lower rpm. 447’s to start then 50’s? Maybe a cut down set of 457’s? I have a set here. I’m not sure if they would be right or not. All kind of experimental.
Man that was fast thanks Shaun. I tried selling these motors for awhile with no luck so I guess I'll have to use them lol. I'm on my way to Boston for work so I'll be stopping in to the ose store and get me a hull and etti controllers
For that size motor I would be looking at a 36" hull just because you will have more room to work with. Twin 1515s can push a good size boat.
That seems like a lot of motor for that hull. I built one with twin aqua craft 36x56 1800 KV motors the motor that comes stock in the revolt. Counter rotating props I have a set of octura x 442's and a set of CNC 44x1.6 detounged and they both work very well running 4-s to each motor. Not my fastest boat by any means but it runs 48 to 50, handles real good and everything stays really cool. It's a little faster with the bigger CNC props but I was surprised how close they are. Hope this information helps with your project and good luck.
Hi Gene - I'll agree with those that brought up the "tight sqeeze" situation. Here's a picture of a customer's Mean Machine I built a while ago with a motor that's the same dimensions of your Neu 1515's (TP Power 4050 3Y 2200KV). Looking at this picture you can see how just one motor and ESC takes up a lot of room :
With just a single motor the MM gets up and boogies :
https://www.youtube.com/watch?v=m2rt6sH8jwE
If you really want to do a twin build with these motors the Cheetah might be an option to consider - more room and can handle the power nicely
Gene
Here is a pic of my twin Mean Machine.
Two 3674"s and I had to cut little slots in the hull to get them to fit.
1515's too big, you mite try a Cheetah hull. a little bigger then the MM.
Larry
Gene, how about a DF Explorer? Cheap and easy access under the hood.
