Results 1 to 10 of 10
Thread: Aeromarine mean machine
    Jun 2012
    ny
    1,135
    Default Aeromarine mean machine
    I have these 2 neu 1515. 1650kv motors and some 4s lipos will these work for a twin mean machine fun run boat? And what props. Thanks in advance for any and all comments
    7,630
    Geno, I think that sounds like a good setup. You’d be running bigger props with the lower rpm. 447’s to start then 50’s? Maybe a cut down set of 457’s? I have a set here. I’m not sure if they would be right or not. All kind of experimental.
    Jun 2012
    ny
    1,135
    Man that was fast thanks Shaun. I tried selling these motors for awhile with no luck so I guess I'll have to use them lol. I'm on my way to Boston for work so I'll be stopping in to the ose store and get me a hull and etti controllers
    7,630
    It’ll be a tight squeeze but I had PB 1800kv’s in a Geico. A pair of Seaking 120’s should do you for ESC’s and yet be small. Etti’s would also work mind you. Look up my Geico build for ideas.
    Mar 2008
    974
    For that size motor I would be looking at a 36" hull just because you will have more room to work with. Twin 1515s can push a good size boat.
    Oct 2015
    174
    That seems like a lot of motor for that hull. I built one with twin aqua craft 36x56 1800 KV motors the motor that comes stock in the revolt. Counter rotating props I have a set of octura x 442's and a set of CNC 44x1.6 detounged and they both work very well running 4-s to each motor. Not my fastest boat by any means but it runs 48 to 50, handles real good and everything stays really cool. It's a little faster with the bigger CNC props but I was surprised how close they are. Hope this information helps with your project and good luck.
    ca
    6,963
    Hi Gene - I'll agree with those that brought up the "tight sqeeze" situation. Here's a picture of a customer's Mean Machine I built a while ago with a motor that's the same dimensions of your Neu 1515's (TP Power 4050 3Y 2200KV). Looking at this picture you can see how just one motor and ESC takes up a lot of room :
    With just a single motor the MM gets up and boogies :
    https://www.youtube.com/watch?v=m2rt6sH8jwE
    If you really want to do a twin build with these motors the Cheetah might be an option to consider - more room and can handle the power nicely
    2,913
    Gene
    Here is a pic of my twin Mean Machine.
    Two 3674"s and I had to cut little slots in the hull to get them to fit.
    1515's too big, you mite try a Cheetah hull. a little bigger then the MM.
    7,630
    Gene, how about a DF Explorer? Cheap and easy access under the hood.
    Jun 2012
    ny
    1,135
    Shawn, just checked that hull out looks nice may have to go with that Steven doesn't have any mean machines right now anyway. I was just at his store yesterday looking at a few different hulls never thought of the delta force.
