Results 1 to 17 of 17
Thread: 8s Rigger Build?
    Sep 2010
    10
    Default 8s Rigger Build?
    Was thinking of a single motor 8s rigger build using a modded Zippkit Twin 45 hull. Was looking at the TP 40" x 100" motor, 1090 kv. But I was wondering whether I should go up to their 56" x 92" motor, 888 kv? Any thoughts? I'm looking to do 70 mph on a 1 mile course. (Heat race boat.) Total mah would be 5,000. (Two 4s packs in series.) Thanks.
    5,614
    You'll want more kv for 8s than 888. I do like the 56 series motors because they are 6 pole but I don't have experience with them on 8s. I might have a Neu 2217 around 1050kv if you're interested. I'll check when I get home.
    Noisy person
    7,560
    What class will the OP be racing? What other boats will he be racing against, gas/nitro/FE? Is he looking for a heat average of 70 mph or a 70 mph top speed?
    The JAE riggers are easy to push, no need for a heavy 56 mm motor. Somehow, 4-pole motors win races and set records all the time. A good quality 40x100-ish motor with a Kv around 1100/1200 will work great. A top speed of 70 is easy-peazy for 8S (example, my JAE does upper 70s on 4S on the oval with a little 1415 motor averaging under 120 amps). For that performance he probably won’t need the weight of 5000 mAh either.
    Jun 2011
    499
    I used a 45 JAE with a TP 40X92(4060) 1050kv on 8S with an X452 and ran low 70's. Still a work in progress on the back burner with other priority projects. I would not go to a 56mm motor because of weight. The 40mm has all the power you can handle.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    5,614
    I would take these guys opinions on it over my own. They're put'n them on the water. My thinking is mere speculation as I haven't.
    Noisy person
    Mar 2008
    937
    All looks good except the 5000 mah. Thats a little on the low side. Better to go 6000+
    7,560
    Mark, he only wants 70 mph.......
    Sep 2010
    10
    I probably will be racing in open rigger/hydro with gas and big block nitro at the club level. I'm not looking for a serious race boat, but mostly a fun boat that will finish a race if I decide to take it racing.
    Sep 2007
    2,256
    A little extra weight will not hurt in the open class. Yes, it will require a little more power to push but it will be more likely to finish.
    The TP 56 series are a good choice as you can swing a decent size prop which helps with choppy race water.
    I have a TP5670 motor in a 8S1P SGX rigger which runs around 72-75mph. I can also run it on 6S swinging gas size props.
    However the TP 56 series are big compared to the standard 40mm motors. A lot will depend on how a motor fits in the hull. The JAE twin nitro hulls are pretty compact and may be challenging to fit large diameter motors.
    You will need a decent 200A 8S ESC and that may be the hardest challenge.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Sep 2010
    10
    What about this for a speed control? Thanks for the info!
    https://www.offshoreelectrics.com/pr...d=hef-HBX1200L
    Mar 2008
    937
    That's a good esc.
    Apr 2017
    QL
    1,022
    Fluid, you do mean 1450 prop i hope not 1415. also did you find the 1450 better than the H7 ?
    Nov 2012
    De
    345
    Quote Originally Posted by rol243 View Post
    1415 is a motor from NUE
    7,560
    The 1415 is a Castle motor with a Kv of 2400, more than enough to push the little rigger very fast. The Octura 1450 is a high lift prop and not very suitable for a JAE without detonguing and cupping. I find the H-7 slightly cupped to be a very good fit for this setup, but if I was starting over I would go for one of the newer ABC 17* rake props. They are more efficient and don’t require any modification to run great.
    Sep 2011
    Tx
    145
    Jay, so ABC 1716 prop for 4s oval heat racing?
    Aug 2018
    Fl
    5
    I have a zipkits envy gas rigger running a tp 5670/840 kv on ten cell. Esc is a swordfish 300 lite with a x462 prop. I am running roaring top 5100s. It is a 1p setup. 7BD6CCB4-86F3-409B-882F-111C13664E16.jpg4EA6F90E-42EC-4096-BECB-8E95C34AB66B.jpg
    Apr 2017
    QL
    1,022
    the 1716 prop is only ok if your running a high kv motor of around 2400 on 4s , this will keep heat down. for motors of around 2200 i have found the H7 to be the best for oval. i did have a castle nue 1415-2400 motor in my jae but the pack and esc just got too hot for comfort after 6 fast laps . 2200 is the sweet spot motor i feel.
