Sounds like the plug is the wrong way around in the receiver. try turning the plug around. Also make sure the throttle trim is centered and the end points forward and back are both at 100%. This esc has reverse and you cannot change it to forward only. I tried to reduce the reverse endpoint so reverse wouldn't function but the esc would not arm.
