Results 1 to 22 of 22
Thread: Lipo size and UL-1 hull
    Dec 2008
    WI
    989
    Default Lipo size and UL-1 hull
    I was concerned that my current lot of 4S 2250mAh packs would not fit in the hull, but I am extremely happy to report that 2 x 4s 2250mAh packs fit in the hull with room to spare.
    This is good news for those of us who have a plethora of 4S 2200 packs from our planes/EDFs. I love the boat's layout... Simple and easy to work on. Kudos Grim/Aquacraft.
    fl
    154
    when my 2 2s1p get low i throw in my 4s1p 4800mah on the left side and it fits just a little tall but i tape the hatch and its all good.
    Dec 2008
    WI
    989
    Good to know. Its seems that there are quite a few options available for battery selection given the size of the tub. My 4S 2250s hold voltage REALLY well and at $46 each, I was super happy that they fit.
    Hopefully others will share info regarding what packs fit vs. those that don't.
    Aug 2007
    MA
    281
    What are the dimensions inside the tub for batteries?...
    There has been quite a bit of discussion whether certain batteries will fit or not fit, it would be so much easier if someone just measured the inner dimensions in front of the motor mount. I am thinking of buying one.
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
    Dec 2008
    WI
    989
    Quote Originally Posted by 10gauge View Post
    Taken from this thread: Link
    "28mm shallowest point (front)
    47mm deepest around the motor bracket."
    Aug 2007
    MA
    281
    Thanks LuckyDuc. Do you have the length measurement too?
    Dec 2008
    WI
    989
    The manual says that the packs must be less than 6"(155mm) long.
    Aug 2007
    MA
    281
    Thanks, LuckyDuc! That's a big help.
    Battery Well: 155mm(L) x 28mm(H) @Front x 47mm(H) @Motor
    Aug 2007
    MA
    281
    Hey, BTW, how's the boat running for you? Have you modified props, strut, etc.?
    Cool
    Actually you can fit longer packs in with ease. My 2S/5000mAh ThunderPowers are just over 6" with the wires and there is over 1/4" of room left at the front of the compartment. Depending on the pack width and thickness, packs from 6.25" up to perhaps 6.4" long may fit. My 4S/3300mAh TPs fit cross-wise in front of the motor, good if I ever need to move the CG forward.
    So far the K-45 seems the best prop when running by myself. In race water that may not be true, I'll find out Saturday. Note I am just trying plastic props - the local club wants to keep prop tweeking to a minimum to keep things more equal. Suits me.
    Dec 2008
    WI
    989
    Unfortunately I have to wait until my lake conditions improve a bit before her maiden.
    Aug 2007
    MA
    281
    Default UL-1: Inner Dimensions for Batteries
    UL-1: Dimensions for Batteries
    Well guys, I've been listening to all the talk over this hydro. I ended up buying a Red UL-1 over the weekend from Steve. The first thing I checked was the inner dimensions for batteries.
    170mm (L) front to motor mount
    28mm (H) @ front
    45mm (H) @ motor
    Plenty of space for any pair of 2S LiPos ever made! I'll have to wait until April to test it. In the mean time, I'll be tuning in for any mods from the one's living in warmer climates...
    May 2008
    OH
    774
    how wide is the battery compartment in the front?
    Jun 2007
    OH
    26
    28mm (H) @ front
    45mm (H) @ motor
    Absolutes are dangerous. These Hobby City 2S 4900 mAh won't fit because they are 175mm long.
    http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
    Dec 2008
    WI
    989
    Quote Originally Posted by jcald2000 View Post
    The width is 143mm
    May 2008
    ZH
    94
    Hey you got one, congrats !
    Remember to test the water jacket for leaks before you take her out for the first time...
    Berry
    Dec 2008
    WI
    989
    Yep. Nice little boat. I can't wait for my lake to thaw.
    Aug 2008
    103
    Quote Originally Posted by no stick View Post
    But these will:
    http://www.hobbycity.com/hobbycity/s...idProduct=8578
    Jan 2009
    fl
    43
    Quote Originally Posted by LuckyDuc View Post
    is that where you can place the battery? wouldnt there be a balance issue?
    im sorry i could be wrong...
    also,does this model accepts a 4s lipo without needing to add/upgrade anything?
    i can just buy me a 4s and bam?
    thanx ahead!
    Dec 2008
    WI
    989
    Yes. You could buy 2 x 4S 2250mAh packs and wire them in parallel for a total of 4500mAh. No upgrade needed to the ESC or motor as it is the same voltage as the recommended 2 x 2S lipos wired in series. I'm using two 4S packs in parallel because I already have them on hand.
    Jan 2009
    fl
    43
    Quote Originally Posted by supafastsupra2 View Post
    that is wonderful news to hear!
    But would i need to upgrade anything if i were to install these batteries in my ul-1? Or just slap them on and go?
    Jan 2009
    fl
    43
    so just for the record will these fit for the ul-1?
    Dimensions: 101x35x33.2mm
    thanx
