Results 1 to 10 of 10
Thread: Serious Setup Question
    FR
    2,096
    Exclamation Serious Setup Question
    Hi,
    I have a Serious setup question, what seup should you choose and why ?
    With a serial setup (high voltage) the current in the circuit is lower, HV esc' s are necessary.
    Dec 2009
    LO
    30
    Hello my friend
    This is a question for your Smash Shark building or another project ??
    It depends of the size of your boat...
    May 2018
    344
    B. I just converted a boat from setup A to setup B and the power difference is night and day even carrying double the MA weight. And its not the additional current capacity - I was well within the C rating of the packs before and they barely got warm.
    Oct 2018
    11
    I think the biggest influencing factor is the decrease in the amp draw when going from 22.2v to 44.4v. It makes it easier for the 750kv motors to reach and hold high rpm than the 1500kv motors on the lower voltage. It’s just more efficient at higher voltages because it is easier to push less amps through all of the wires and circuits. The parallel 6s packs in A have twice the c-rating amp output capability and double mah capacity when compared to the same packs used in B, but run time probably isn’t much different between the two options.
    Interesting experiment for sure
    Disclaimer- I’m not an electrical engineer that specializes in AC motor design.
    Apr 2017
    MT
    155
    I would power the ESC's separately regardless of if you are doing series or parallel setups.
    Sep 2007
    2,783
    The benefit of going with a 12S1P set-up is halving the current the ESC's need to push. This may reduce the cost of the ESC's assuming you have not purchased them. It could also have the opposite effect depending on the power level, where high current 6S ESC's may be cheaper.
    Depending on how hard you are pushing this set-up the HV approach will be more efficient, but only slightly.
    If i were choosing it would come down to reliable ESC's in both ranges. There are several good 6S ESC's and several good HV ESC's.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    FR
    2,096
    Quote Originally Posted by Thunder29 View Post
    Rx battery? 2S LiFe in both setup, 6,6 Volts.
    7,279
    Looking forward to actually seeing a finished product someday.
    FR
    2,096
    With 12S voltage batteries and ESC' s should be warmer, less power lost with this setup
    Jun 2010
    Mi
    738
    Tyler Garrard ( RaceMechaniX) is spot on. I would argue that the efficiency effect is significant, but this is semantics.
    In general, power loss (and heat generation) is:
    Power loss = (current)*(current) * Resistance.
    To go from a 1500 KV motor to a 750 Kv motor, the resistance should double, but the current is halved. Because loss is a function of the current^2, the total loss goes down in HV setup.
    There can also be other efficiency effects, like the motor winding reaching field saturation at high current, but you can't say that part for sure without specific knowledge of the motor.
    Disclaimer: I AM an electrical engineer who works with large AC motors (50-500 kW)
