Results 1 to 9 of 9
Thread: carbon fiber reinforcement
    Mar 2018
    TX
    109
    Default carbon fiber reinforcement
    What weight of carbon fiber fabric should I use to reinforce a fiberglass hull?
    Jul 2016
    4,117
    I use a standard 2x2 weave 3K cloth. It still conforms to the corners well enough. I've used multiple layers on particularly flimsy sections of some hulls, or in problem spots like seams.
    Mar 2018
    TX
    109
    Thank you sir. That will help me out, any particular suppliers you prefer?
    Jul 2016
    199
    Aug 2010
    uk
    2,887
    You can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
    Jul 2016
    4,117
    Yep, what I use is a twill weave. I misspoke when I said plain.
    Mar 2018
    TX
    109
    Quote Originally Posted by martin View Post
    Thanks guys. Greatly appreciated. I like that combo kit with the resin. Would Gflex epoxy work as well or should I go with a resin and hardener intended for carbon fiber?
    Aug 2010
    uk
    2,887
    Quote Originally Posted by tjj atx View Post
    No you want a laminating type resin & hardener like west 105 resin + the appropriate hardener to use on carbon or glass cloth ( other makes available ). Gflex is a thicker adhesive for bonding.
    Mar 2018
    TX
    109
    Thanks again guys. All your responses have been more than helpful.
