Results 1 to 4 of 4
Thread: How to get ZTX Seal 200A esc to work with TP motors
    Aug 2018
    on
    80
    Default How to get ZTX Seal 200A esc to work with TP motors
    For some reason the seal 200a esc will not work with the tp motors. Works fine with every other type of motor that I have tried but not with TP
    If hooked up to T) motor the motor just vibrates a bit when you give it throttle.
    Dec 2018
    TX
    122
    Quote Originally Posted by Dave Rumble View Post
    I have to assume there is some internal issue with the TP Motor. It is setup like any other brushless motor. If other motors are working with the ESC then the ESC is good.
    -Liberty
    Jul 2016
    4,119
    There were reported problems with the 300A ZTW ESC and some TP motors, I believe it was related to the number of poles. I suppose this is similar.
    https://forums.offshoreelectrics.com...ho-is-using-it
    Aug 2018
    on
    80
    The TP motors are new and run on both the T180 and with the Seaking 180 with no issues at all.
