Results 1 to 19 of 19
Thread: 48 inch open mono race build info
    Dec 2013
    Fl
    15
    Default 48 inch open mono race build info
    Hey guys, I am a gas racer looking to build a 48 inch ARD Assault mono for the open mono class in my district. I scrolled through a bunch of threads here on the site and one common theme seems to be the castle 2028 motor. Seen a lot of different ESC’s used, Castle, MGM etc. This would not be my first FE boat but definitely the first one this large. I wanna make sure it’s durable and plenty fast. I already know the hull is the best rough water mono around for heat racing (IMO). Thanks for any and all help and suggestions. John
    Jun 2012
    ny
    1,135
    Quote Originally Posted by JD/QD View Post
    What's your budget? Low end would be the 2028 and etti 220 esc
    Ga
    5,266
    https://forums.offshoreelectrics.com...or-John-Snider
    https://www.youtube.com/watch?v=4XeOsbN1Ik8
    NEU 2230 1Y 725kv, Castle Hydra HV200, M cut Octura X465, 10s2P.
    This set up (as is) held the IMPBA T Mono 1/3 mile oval record and still holds the 1/4 mile oval record.
    And Ken, it will hold the 1/3 record again...
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Dec 2013
    Fl
    15
    Hey Gene, thanks for the reply. Low end is fine with me as long as it can get the job done repeatedly. How hard would I be pushing that motor? How long can the bigger motors go between rebuilds if they need to be rebuilt at all?
    Dec 2013
    Fl
    15
    This set up (as is) held the IMPBA T Mono 1/3 mile oval record and still holds the 1/4 mile oval recorquited.
    Doug, thanks for your response. That boat is impressive, the price on the motor is as well, lol. Any idea what the top speed was in that video?
    I’ve seen quite a few gas Speedcrafts run well also. Does Castle still make those ESC’s? I thought I heard they were not.
    Ga
    5,266
    I never put a GPS in the boat but it will run with the best out there. The motor doesn't know it's in the boat. I'd love to put it in a 54-55" boat with more control.
    I had no idea the motor was 8 bills now. Yes Castle is gone. Etti, ZTW, or Swordfish would be your go to control now.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Jun 2012
    ny
    1,135
    I personally have never had an issue with the Castle 2028 and see many people on here use them. For the price imo can't be beat. Maybe someone else can chime in here. And I prefer the etti esc's a little hard sometimes to program you need a quiet place and need to concentrate on the beeps and tones.
    Jun 2012
    ny
    1,135
    Hey Doug, what's an M cut on a prop? Thanks bud.
    Ga
    5,266
    Hey Geno,
    I cut the tongue off like the M series Octuras. https://www.offshoreelectrics.com/pr...ctura+M+Series
    They are progressive pitch props so the tongue can keep you from getting the most out of the prop. You can see in the video that the boat doesn't need the additional blade area to get up. I wish they offered the whole X series in a M series. It sure would save a lot of work.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Dec 2013
    Fl
    15
    Thanks for the info Gene and Doug. I talked to Ken Haines at our race In Broward this weekend and picked his brain a bit. He likes the Neu 2230 motor as well.
    Dec 2013
    az
    1,228
    Can’t go wrong with a castle 2028 and swordfish 300x
    Dec 2013
    Fl
    15
    Thanks for the suggestion Ray. This type of set up would need to be run on 10S correct?
    Dec 2013
    az
    1,228
    Yes.. or 8s.. I’ve run it both ways.. 8s I run a 72mm prop.. 10s a 63mm prop
    Ga
    5,266
    The price on the 2028 seems legit.
    http://www.castlecreations.com/en/20...or-060-0054-00
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Dec 2013
    Fl
    15
    Quote Originally Posted by rayzerdesigns View Post
    Again, good info, thanks. 2 or 3 blade? I believe someone said a 270/2 for their 2230/ hydra setup?
    Dec 2013
    Fl
    15
    I agree Doug, lol. In the future I wouldn’t mind laying out the money for the Neu motor. Just don’t know if it’s worth it right out of the gate without knowing if the open mono class is going to last. We did have a pretty good turnout this last weekend though.
    Dec 2013
    Fl
    15
    I almost hate to ask this last question because it’s probably going to be like someone asking which two stroke oil to use over on the gas forum but… Any recommendations for batteries for this type of set up? Are you guys using four packs whether 8S or 10S for the extra weight and/or COG adjustability?
    FR
    2,094
    MHZ – Scorpion Motor HK-5035 - 760kV
    Max Continuous Power: 5800 Watts
    Maximal Peak Power: 8100 Watts
    Incredible weight/power ratio
    Dec 2011
    560
    Giant Power 170c 5-6000 mah 10s 2p (4 packs)
