Results 1 to 20 of 20
Thread: Propeller talk post
Hybrid View
    Dec 2010
    NY
    3,119
    Default Propeller talk post
    OK guys I will add stuff to this post as we go along, I'm ignoring any questions of what prop do I need on my set up,, For argument sake All model boat props were 2 blades in the 80's so when you wanted a 2 blade prop you asked for a 440-450-460-470- ect,,, now when the 3 blades came out or got discovered back then they became 440/3-450/3-460/3-470/3 ect,lets all get on the same page
    Jul 2016
    4,119
    What's your preferred method to describe an ABC prop (1715 for example) in terms of the rake angle and blade area, 1715 17-45?
    Dec 2010
    NY
    3,119
    1715 I'm assuming 2 blade 17* unless told 1715/3 but now with all the new ABC props I need to be careful
    AZ
    8,010
    Why not use the manufacturer’s designation: 1715-17-45(2) CLL?
    Dec 2010
    NY
    3,119
    2017 ABC prop chart
    Attached Files Attached Files
    Mar 2009
    OH
    1,585
    17 is the diameter 15 is the pitch angle. if you multiply 17 times 15 it equals 2.55” of total pitch. For every turn the boat travels 2.55”. There is slip. Can’t be much simpler.
    AZ
    8,010
    Cool
    The problem is how to ask for the exact ABC prop you want.
    diameter - pitch ratio - rake - blade area - number of blades - chopper/cleaver - left or right hand
    Use the maker’s prop designation. Can’t be any simpler - if you want to identify a specific ABC prop.
    Oct 2009
    MI
    6,192
    I had trouble where I asked for props he hasn't even designed yet. Like I wanted something in particular that doesn't exist. That'll learn' me! Check the danged chart.
    Noisy person
    Oct 2009
    FR
    2,096
    Very easy
    Dec 2010
    NY
    3,119
    good Visual the 10* is a lifter it lifts the transom and as it does that it lowers the bow as the rakes get higher there is less transom lift
    Jul 2016
    4,119
    Quote Originally Posted by dasboata View Post
    Cool, I didn't know the relationship between rake and lift. Does the rake angle change the thrust cone too?
    Dec 2010
    NY
    3,119
    yes Ryan you can visualize the thrust will be tighter on the higher rake props
    Jul 2016
    4,119
    Ok, makes sense. Does a narrower thrust cone mean less forward propulsion? Does a narrow vs. wide cone matter when considering a boat that turns vs. SAW?
    Dec 2010
    NY
    3,119
    common sense says yes,, tighter thrust cone more thrust , I don't think the turns matter if your using a strong enough servo
    Oct 2009
    FR
    2,096
    This is an informative contribution picture
  16. #16
    Feb 2008
    GB
    2,731
    How big would the hub have to be to be able to balance a 45mm single bladed prop?
    Do you think it would be an advantage, or would the extra size and weight of the bigger hub more than counteract the extra efficiency of the bigger blade running in cleaner water?
  17. #17
    Dec 2010
    NY
    3,119
    never thought about it as it a waste of time for me as someone would of done it already
  18. #18
    Jul 2007
    or
    1,088
    Fairly large. Probably need to use small tungsten slugs. We did it with pylon racing props, but they were compression molded carbon fiber.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
  19. #19
    Mar 2012
    IN
    35
    I've made a few. The hubs are not round, but when rotating the net Hub area is around 1/2" or slightly bigger. They do work, but I didn't see any huge revelation.
    Obviously balance is the key and difficult to achieve. A novelty for sure.
  20. #20
    Dec 2010
    NY
    3,119
    [QUOTE=Alfa Spirit;735707]Hummm ...
    [IMG]ht
    this is not show and tell please remove your post this is a informative contributions subject
