Results 1 to 5 of 5
Thread: Do I need Turn Fins & Trim Tabs?
    Apr 2019
    7
    Default Do I need Turn Fins & Trim Tabs?
    I have ordered the forum members recommended power setup for my Graupner Electro Vee! Do I need to also install Trim Tabs & Turn Fins?
    If so what size?
    I’m a Noob at boats!
    FR
    2,096
    Who can answer ?
    Run your boat without those tuning parts first.
    The ElectroVee was a vacuum-formed hull without sharp chines or strakes. As such it tended to slide a bit in turns. That wasn’t much of a problem with the 1990s power setup it was designed for, but with today’s power maybe not so good. What power combo is the OP using - motor, ESC, voltage and prop?
    Apr 2019
    7
    3656 1840 KV Leopard
    OSE Raider 150 Esc
    4S1P 5000 50C Lipo
    Tfl stinger and rudder
    3/16 shaft
    442 prop
    FR
    2,096
    This is a small Arrow, you can use Kyosho trim tabs
