Results 1 to 9 of 9
Thread: Big oops........ Help.
    May 2009
    UK
    1,018
    Default Big oops........ Help.
    Hi guys, was finishing off my HPR build, dropped a clanger..
    Overtightened a 3mm hex and rounded it, turns out its a micron too deep (despite me measuring everything up with correct size washers / bolts)
    Anyway theres a point on the Lehner 'Hi-Amp' fan when I rotate the shaft it catches, Any suggestions on removing this? all I need to do is loosen it half a turn...
    Uk SAW record holder
    Nov 2012
    De
    356
    Hi Liam
    I am sent you a link to some high tensile SS bolts to use on PM.
    To resolve you problem, use a Dremel to cut a slot and use a flat head screw drive to unscrew.
    4,117
    I agree, slot it with a dremel would be my first fix. Sometimes I've been able to get a bite using a larger standard sized allen or even a torx bit in a stripped cap screw.
    May 2009
    UK
    1,018
    Dremel is my last resort, little bit scared of getting metal filings in the motor too..
    I've epoxied a Allen key in the bolt and will try in the morning..
    7,279
    Epoxy might not be the best...try JB Weld if the epoxy fails.
    2,728
    Often you can hammer a Torx driver into the hex to get one out.
    May 2009
    UK
    1,018
    It was super tight, no room to get anything at it... Anyway, got it out with a hammer and a punch, all it took was to release a tiny bit of tension and it came out.
    Although I have now built it, went to setup my ESC and the speed controller decided to just smoke........
    ca
    6,962
    Liam, (or anyone with a similar dilemma) -
    Having "been there" many times over the years (building boats & motorcycles) I've used this solution - needle nose vice-grips snuck into place & squeezed waaay tight & after a few tries to get it lined up it works most of the time. Often helps to recite obscene proverbs while applying pressure.
    I see you have that one solved as I was posting this. Enjoy your new ESC [Oh wait ]
    Jul 2013
    IN
    42
    I just hate when this happens. Often times, i swap out as much bolt/screw/nut hardware with American made synonymous hardware. It has helped A LOT.
