Results 1 to 10 of 10
Thread: Octura vs CNC prop
    Apr 2019
    Iz
    36
    Default Octura vs CNC prop
    [B/]octura for high performance or CNC[/B]
    Feb 2008
    GB
    2,728
    What sort of high performance, do you want high efficiency or flat out high speed?
    For the Endurance racing that I do low blade area CNC prop series from Dr Props, Tenshock and TP are signifantly more efficient than a stock BSP Octura, and you have to do some significant thinning and reshaping of the Octura blades to get that back. To take that to an extreme the Graupner carbon props are the most efficient props available and while they are very fragile they give more performance per watt than any metal prop possibly can.
    On the other hand the CNC props we race with and even the modded Octura props I race with will fold up like a flower if I use them with SAWs power levels. Octura, ABC and Prather cast props with near stock thickness are much stronger and thus will be capable of handling more power and thus reaching higher speeds.
    The one exception to that is Dr Prop, who CNCs his props from stainless steel not aluminium alloy, his NAMBA range are much thicker than his Naviga range and can handle some serious power.
    Apr 2019
    Iz
    36
    want high speed, Setup tp4070/1090 KV 10sx2
    Nov 2012
    De
    356
    Quote Originally Posted by Yakoo View Post
    Speak to Chris Hoffman he will sort you out with the props you need
    May 2019
    3
    Not necessarily
    May 2019
    3
    How do I reach Dr. Prop?
    Nov 2012
    De
    356
    Go on face book and search Alex Prop and you’ll get his details
    May 2019
    3
    StevenBryant..
    Thank you.
    Sonsone
    Feb 2008
    GB
    2,728
    Or his other contact details are on his website
    http://doctorprops.torgg.com/
    Oct 2019
    Ca
    14
    Quote Originally Posted by StevenBryant View Post
    Alex is one cool dude
