Results 1 to 11 of 11
Thread: Proboat Prop problem
    Mar 2019
    NY
    2
    Default Proboat Prop problem
    Hello all this is my first post and I have a question about props for my Proboat Veles. The manual states that the box stock prop is recommended for up too 4s and if using 6s constantly to use factory replacement part # PRB282027 which is a misprint it's actually #PBR282028. So my question is has anyone run into the problem of the hub on the replacement being too short too allow tightening down of the prop...? I attached pictures of Box stock and Factory replacement.
    Thanks in advance. Ken
    AZ
    8,010
    Welcome aboard. I don’t have a Veles but this condition is not uncommon. You need a soacer between the prop and the nut. You can make one from a piece of brass tubing, or by some here:
    https://www.offshoreelectrics.com/proddetail.php?prod=ose-83280
    Mar 2019
    NY
    2
    Thanks, I was thinking about machining a spacer but wasn't sure if it would have any ill affect on the prop shaft or the strut bushing. I will just order a couple from here.
    Oct 2009
    FR
    2,095
    Did you try a spring ?
    LoL
    Dec 2010
    NY
    3,118
    we used to use fuel tubing in the old days
    Mar 2009
    OH
    1,585
    Quote Originally Posted by dasboata View Post
    And still do.
    Dec 2010
    NY
    3,118
    Quote Originally Posted by photohoward1 View Post
    And still do.
    right on !!!
    Mar 2015
    ON
    166
    Is it not possible to just loosen the drive dog and move it further back?
    Oct 2009
    FR
    2,095
    Quote Originally Posted by Capt'n Crash View Post
    You can' t move the DD each time you change the propeller. The lenght of the flexshaft is not adjustable
    Mar 2015
    ON
    166
    If that's the case then I would email Proboat customer service and see if they have a better solution to the problem.
    ON
    2,910
    Quote Originally Posted by Kenny Joz View Post
    The prop in the second picture has got a shorter hub then the prop in the first picture.
    Those two props are not the same length.
    Larry
