Results 1 to 7 of 7
Thread: Neu 1521 jet unit no cooling esc?
    May 2009
    UK
    1,018
    Default Neu 1521 jet unit no cooling esc?
    Hi,
    So I have a large 1,3m long mono im converting to direct drive, it was a geared belt drive...
    I really would like to not drill the hull if I can get away with it but...
    Would a 1521 1Y on 4s driving a 30 (maybe 35mm) jet unit require cooling?
    Which ESC should I go for? I have the as26's but they don't work very well with 4 pole hence my purchase of Lehner 2250's for my other boat and these are spare...
    I was thinking about longer run times using 10,000mah packs / side... maybe cooling would be needed?
    Uk SAW record holder
    Mar 2011
    BC
    7,630
    A jet unit will be harder on things than a standard prop setups. A jet sees more of a constant load. So yes water cool ESC and motor. Just tap a fitting to the unit after the impeller and you’ll be good. You can also tap the exiting water into the unit before the impeller.
    Mar 2011
    BC
    7,630
    Oh and most jet units like a lower rpm, say 20’ish thousand.
    May 2009
    UK
    1,018
    Hmm, how do these work with NEU motors?
    https://www.offshoreelectrics.com/pr...=ose-R-150C-v2
    I could always run them 3s with them ESC, my current ESC are 4-8s so for some reason I just figured in that range...
    And cooling... for some reason I have the urge to try and internal cooling system, little bit of a faff but could be cool... weight isn't a issue with this boat so thinking a nitro fuel tank, one of these and some ice cubes https://www.mhz-powerboats.com/shop/...ater-pump?c=81
    May 2009
    UK
    1,018
    correction, they are actually 28mm jet units...
    Would 2x 1521 1Y on 4s really need cooling spinning a 28mm plastic impeller...? hmm
    Mar 2011
    BC
    7,630
    Quote Originally Posted by vvviivvv View Post
    Have you got a pair of old Graupner drives there?
    May 2009
    UK
    1,018
    Yeah,
    anyone care to comment how the OSE esc's work with Neu motors, specifically the 1521 series?
