Results 1 to 4 of 4
Thread: Help With Motor Sizing
    Apr 2019
    NC
    7
    Question Help With Motor Sizing
    Howdy folks! What is a good alternative to a 3.5cc outboard in an electric outboard? I was looking at this one! Not sure if it is what I need! It will be going on a 30” Scrachbuilt Tunnel Hull!
    Description
    TFL Scale Outboard Motor (W/Motor)
    TFL SSS 3660 with 4mm male connectors.
    Motor diameter: 36mm
    Motor length: 60mm
    2075Kv with 5mm Shaft
    Installed metal water jacket.
    185mm from bottom of skeg to top of outboard cover.
    Cover is 55mm wide
    550 Grams(approx)
    Drive: 4mm Propeller shaft, requires drive dog style propellers.
    Fits upto 48mm Prop
    Gear driven
    ma
    8,693
    Quote Originally Posted by BigJohnnyNC View Post
    Description
    Motor length: 60mm
    Cover is 55mm wide
    550 Grams(approx)
    Fits upto 48mm Prop
    Gear driven
    if you are going for scale looks and performance that works.
    if you want fast/race type speed, this is what I would use
    https://www.offshoreelectrics.com/pr...ullet-outboard
    Steven Vaccaro
    Apr 2019
    NC
    7
    Thanks a Million! I shall Order one Payday!
    Oct 2009
    FR
    2,095
    I have this brushless motor mount with XERUN 4274 - 2000KX, perfect for a 4S setup.
    Brand new, never installed, friendly price.
