Originally Posted by
BigJohnnyNC
Howdy folks! What is a good alternative to a 3.5cc outboard in an electric outboard? I was looking at this one! Not sure if it is what I need! It will be going on a 30” Scrachbuilt Tunnel Hull!
Description
TFL Scale Outboard Motor (W/Motor)
TFL SSS 3660 with 4mm male connectors.
Motor diameter: 36mm
Motor length: 60mm
2075Kv with 5mm Shaft
Installed metal water jacket.
185mm from bottom of skeg to top of outboard cover.
Cover is 55mm wide
550 Grams(approx)
Drive: 4mm Propeller shaft, requires drive dog style propellers.
Fits upto 48mm Prop
Gear driven
if you are going for scale looks and performance that works.
if you want fast/race type speed, this is what I would use
https://www.offshoreelectrics.com/pr...ullet-outboard
Steven Vaccaro
