Page 2 of 2 FirstFirst 12
Results 31 to 51 of 51
Thread: "The Gecko" aka Miss Geico
  1. #31
    Jan 2019
    Nv
    75
    20190808_194143.jpg20190808_194248.jpg20190808_194443.jpg20190808_194600.jpg Moving right along. Servo mount, carbon posts with nylon inserts. Just finished the dress up washers.
  2. #32
    Jan 2019
    Nv
    75
    20190808_194203.jpg20190808_194143.jpg20190808_194248.jpg20190808_194443.jpg20190808_194600.jpg Just finished the servo mount , carbon posts with nylon inserts. Spun up some dress washers too. Couldn't have done it without the help of Taylor, "Big Mister".
  3. #33
    Jul 2016
    4,121
    The orange epoxy is a nice touch. Did you make your own brass barbs for the water pick-ups? If so, how did you make the cone pieces? I ended up just soldering on a small section of brass tube one size larger to give the hose something to bite on.
  4. #34
    Jan 2019
    Nv
    75
    No i didn't, but that's not a bad idea. Nor is the way you're doing them. That works too. I think i could cut my own tho, using the rotary table and like a 60° dremel burr, or something of that nature. I had purchased these from OSE. Quick and dirty! Thanks for the compliment. I dumped a lil createx in the g flex. Makes it a little stringy and a tad thicker too especially with micro fibers in it.
  5. #35
    Jan 2019
    Nv
    75
    I'd love to share some of my recent progress, but for some reason every time i upload it says "upload failed". Any suggestions?
  6. #36
    Jan 2019
    Nv
    75
  7. #37
    Jan 2019
    Nv
    75
    Alright! I'm back to posting pictures. A little more of my progress, and some more handy work on the mill.
  8. #38
    Jan 2019
    Nv
    75
    20190914_091900_compress40.jpg20190914_092007_compress5.jpg20190914_091916_compress78.jpgI got the linkage close. A little more tweaking and I'll have it. What a long drawn out process fabricating the servo horn, clevis, and pins out of stainless steel socket heads.
  9. #39
    May 2018
    TX
    344
    Your machine work is gorgeous. What machine tools are you using? I'd love to have a small lathe/mill someday.
  10. #40
    Jan 2019
    Nv
    75
    Quote Originally Posted by Mike W View Post
    Thank u so much Mike. I use a lot of 3 flute small diameter end mills 1/8",3/16",1/4", serrated flutes for roughing. Drill point 2 flute end mills 90?and 82? for chamfering, spotting and fine finish. I'll post some pictures of some of my favorites later.
  11. #41
    Oct 2009
    FR
    2,096
    Cool KBB style small cat.
  12. #42
    Jan 2019
    Nv
    75
    Quote Originally Posted by Alfa Spirit View Post
    I'll take that as a huge compliment, thank you. I learned a lot watching his builds. It's a shame his forum doesn't exist anymore.
  13. #43
    Jan 2019
    Nv
    75
    20191004_053027_compress73.jpg20191004_053149_compress51.jpg20191004_053209_compress1.jpgA little more progress. Esc mount painted and ready for clear coat. I quick look at half the power plant. We're sneaking up on it. Won't be long now.
  14. #44
    Jan 2019
    Nv
    75
    20191010_205601_compress68.jpg20191010_205636_compress49.jpg20191010_205601_compress68.jpg20191010_205543_compress91.jpg Moving right along. Carbon posts for esc mount are in. Got the mount all cleared up. The carbon really comes to life under some high solids clear.
  15. #45
    Jan 2019
    Nv
    75
  16. #46
    Jan 2019
    Nv
    75
    20191022_173838_compress29.jpg The race gas arrived today straight from Singapore!
  17. #47
    Jul 2016
    4,121
    Nice. I always got pretty quick shipping direct from Revo.
  18. #48
    Jan 2019
    Nv
    75
    20191025_054419_compress80.jpg20191025_054507_compress58.jpg20191025_054455_compress86.jpg Got all the soldering done. That was a lot of work. Gonna start routing wires and start plumbing.
  19. #49
    Jan 2019
    Nv
    75
    20191105_200511_compress92.jpg I'm not the only one dreaming of finishing this thing. Sometimes he even helps!
  20. #50
    Jun 2020
    La
    2
    Hay man if you don?t mind where did you get the outdrive made and your rudder
  21. #51
    Jan 2019
    Nv
    75
    Quote Originally Posted by Rayhynes View Post
    I machined the strut standoffs, rudder standoff, and rudder on my benchtop mill. There should be pictures of all this being made except the rudder, i forgot to snap some pictures of it. Struts are OSE 3/16" cut down and turned the bevel using my rotary table. Should be some pictures of this as well.
