Results 1 to 4 of 4
Thread: Ok setup?
    Jun 2013
    25
    Default Ok setup?
    I'm looking at putting a vee bottom together and want to make sure what I have will marry up well. I have an ML Boatworks 54" Fountain hull, a TP 5860 4Y 730kv motor, and Flier 300a boat esc. The hull the motor and esc were in ran 12s. Will this work well or be better suited to a different hull?
    Apr 2015
    199
    I think you should be on the right track. Only issue I see is 12S is going to be pretty hot with that kv motor. To keep the amps and speed in check you will need to drop down to a smaller prop than would be ideal for that big of a hull. You might do better at 8-10S depending on what you are wanting to do with this build. All out speed, sport, long run times, etc.
    Aug 2008
    7,080
    You got a pic of the boat, might help us evaluate, in addition to questions in previous post.
    "Look good doin' it"
    See the fleet
    Jun 2013
    25
    Thanks for the info so far. I had to lift this from Mike's site, so, sorry Mike.Screenshot_20190405-200414_Samsung Internet.jpg
