Results 1 to 13 of 13
Thread: Need advice about this carbon hull
    Oct 2009
    FR
    2,096
    Default Need advice about this carbon hull
    I made a search but nothing, do you know this hull ? I don' t know the brand
    Sep 2007
    CA
    1,707
    Where did you find the photo? What size is it?
    AZ
    8,010
    It appears to be one that is sold by DYMotorshop. It’s 75 cm long and has lots of lift. Probably not the best for high speeds.
    http://www.dymotorshop.com/index.php...roducts_id=463
    Oct 2009
    FR
    2,096
    '' and has lots of lift ''
    Where did you read that ?
    Sep 2007
    CA
    1,707
    https://www.ebay.com/itm/750mm-29-5-...4AAOSwkZhWRUML
    I'm sure Fluid can simply look at the bottom of a hull and just know that from experience.
    Oct 2009
    FR
    2,096
    Yes, this hull is a Deep Vee, not a flat V.
    Look at MHZ hulls, they are Deep Vee. The COG must be near 28%, no turn fins needed.
    Oct 2009
    MI
    6,192
    Center strakes right to the transom. It's going to ride high on the keel with almost nothing in the water. Small rudder input and it will lay over into a tight radius. Fine at low speed where you can maybe carve it out but at high speed.......sketchy. Likely will hook or tumble. Just my opinion from running similar strakes.
    There's some video on youtube of one of these. Can't remember who had posted it.
    Noisy person
    Oct 2013
    la
    8,740
    I think jessej had one of these....
    Mar 2014
    IA
    165
    Strakes are no big deal in modding the strakes. Just find a boat of same size and grind off the strakes if you really love the looks of boat. Just fill in and paint and then cover with CA and sand. Make sure you make mod, same as the boat of same size.
    Aug 2008
    CO
    7,080
    Quote Originally Posted by kfxguy View Post
    Travisbe right. That was my first comment after Travis made me buy one.
    I took the strakes off 5-6” Forward I think. There is a thread if interested.
    "Look good doin' it"
    See the fleet
    Mar 2014
    IA
    165
    I went looking for thread under carbon hull and different names but came up empty.
    Jul 2016
    4,131
    Quote Originally Posted by Norwest View Post
    I remember this thread about the TFL integrated drive he installed in that hull: https://forums.offshoreelectrics.com...ono&highlight=
    Oct 2009
    FR
    2,096
    Thanks, this hull is very nice, very cool with a nice semi-scale finish.
    Is it an Outerlimits or a Fountain ?
