Results 1 to 13 of 13
Thread: Build in extra capasitors??
    Feb 2019
    DK
    25
    Default Build in extra capasitors??
    I’ve been wondering. What if you build in one or two extra capasitors on the battery side of the ESC. Won’t they help the ESC in getting enough current when you hit full throttle? I know the ESC allready have them installed, but i’m thinking one or two with 80voltage and with 100.000uf. Some big ones.. They don’t weigh much and they sure would help the batteries.. anyone tried that?
    Nov 2012
    De
    356
    Most circuit and SAW racers I know install capacitor banks, I use Rubicon ZL or ZLH caps, I keep the voltage the same as the ones on the esc. I use 5 caps for circuit and 9 for SAW in the range of 540 to 680 uf per cap. I’ll attach some picture for you shortly
    Feb 2019
    DK
    25
    I have to ask.. what does SAW stand for? I think i may be the only guy from Denmark here in this forum 😂
    My 320amp esc can handle 16s but im keeping it at 15s. So maybe i should look for some caps that can handle a minimum of 63v or?? Im calculating that on the 4,2v on each sell when they are fully charged.
    Nov 2012
    De
    356
    Quote Originally Posted by HeineDenmark View Post
    Hello Heine,
    SAW is straight line racing, you make two passes and they take the average speed of the runs, you are not the only boater from Denmark, EmilWilkens is also from Denmark.
    You need to check the caps on the esc and use the same voltage, 63v is too close for 15s I would use higher.
    https://youtu.be/Fr7D9_V4UZs
    Feb 2019
    DK
    25
    Holy c**p thats a fast one!
    Mine is still in the making. Blew the shaft and prop at my second test. Didnt even made it to the fine tuning of the prop angle and height. Link below. Reached 116 km/h
    https://youtu.be/0T_4tIjd6A8
    Nov 2012
    De
    356
    That a nice running-boat, what happened to the shaft?
    Nov 2012
    De
    356
    Feb 2019
    DK
    25
    I used a cheap alloy prop from another boat i have. I think i was to weak. Also the strut is not suitable for the high rpms becaus of the small bearings inside. So they burned and blew up the end of the strut, which bended the axel... bummer
    Nice caps there. Think i’ll add that to the boat while waiting for parts..
    Feb 2019
    DK
    25
    Just added a pair of caps. Found two big ones that suited the setup. Below there’s a link to a video of the setup. Dont mind my crapybuild wooden battery trays 😂
    https://youtu.be/v5kdWK3zWwA
    Feb 2019
    DK
    25
    Feb 2008
    GB
    2,730
    The smaller the caps are the quicker they can charge and discharge, so a bunch of smaller caps is better at smoothing the high frequency voltage ripple that we are trying to protect the ESC from than a couple of big ones, even if they have less total capacitance.
    Feb 2019
    DK
    25
    Ohh okay. I did’nt know that. Well then i’ll try finding some small ones instead. Thanks for your reply.
    Feb 2008
    GB
    2,730
    There is a long stickied thread by dr wayne on here that you might want to read. https://forums.offshoreelectrics.com...ght=capacitors
