Results 1 to 13 of 13
Thread: Setup for a 39'' - 1 meter catamaran ?
    FR
    2,096
    Question Setup for a 39'' - 1 meter catamaran ?
    I want to build a 39" / 1 meter catamaran with a twin setup, I need help to choose between those :
    2 x 4S, 3660 - 2400kV motors
    2 x 5S, 4060 - 1900kV motors
    Thx
    9,402
    What is your goal for this project, speed, sport, racing?
    Those are not very robust motors for a 39" cat.
    FR
    2,096
    Fast sport, not SAW
    Mar 2017
    VI
    371
    4060 1900kv 5s would be the better option. Is the 4060 a tp motor?
    If yes. That is a very good motor.
    FR
    2,096
    Motors are fine, 2 x NEU 1512 - 1900kV and 2 x Tenschock 3660 2400kV.
    @Speed3 , you prefer 5s batteries, right ?
    Dec 2009
    LO
    30
    Quote Originally Posted by Alfa Spirit View Post
    Fast sport, not SAW
    Have you already dropped your carbon monohull project Alain ?
    It takes place on a shelf to store a 39" catamaran, take care !
    One day, you will build your own boat, I know about it, don't give up
    Sep 2018
    uu
    65
    I ordered 4082 1900kv x 2 to spartan
    Driver Toni a. K. a speeder
    Mar 2017
    VI
    371
    5s with a 1900kv would have a lot of advantages over 4s and a 2400kv.
    You would have a little longer runtime.
    Secondly the lower kV would hold rpm better underload resulting in higher speeds.
    So a faster boat with additional runtime and cooler electronics is the benefits of choosing the 1900kv, 5s route.
    FR
    2,096
    Quote Originally Posted by Speed3 View Post
    Thanks Sppeed3, 5s batteries look better imho. A single question is about the weight ...
    Mar 2017
    VI
    371
    Sometime back I ran a leopard 4092 2080 kV on 4s in a revolt and an m545. The best I saw on GPS was 48mph.
    I also ran the leopard 4092 1730kv in the same boat on 5s with the same m545 and my best was 54mph on GPS.
    I think this is kind of similar to which to pick, a 2400kv and 4s or a 1900kv and 5s.
    FR
    2,096
    Here is the typical setup for a MHZ Mystic 114 cm, 2 x 7S and 2 x NEU Motors 1521.
    So on a 100 cm catamaran 2 x 5S look right with 2 x NEU Motors 1512 - 1900kV.
    Mar 2017
    VI
    371
    A cat in the 100cm range would run well with 1512 motors. But if 4082 same size as tp 4050 or 1521 motors were available I would prefer that size over 1512 size motors.
    FR
    2,096
    Yes but 1512 are NEU Motors and I use 2 Motors, high quality, enemy of the performance is the weight, I hope this is a good setup ...
