Results 1 to 28 of 28
Thread: Prop bore diameter !
    Apr 2018
    OZ
    276
    Default Prop bore diameter !
    Just asking if you go from a 3/16 bore prop octura and open it up to 1/4, in a saw type setup would it still be strong enough?
    has anyone done this ?
    Jun 2010
    Mi
    738
    I would think you would weaken the prop hub substantially, and introduce all sorts of balance issues.
    0.187 flex is plenty strong, Especially the welded ones from Wholt RC.
    http://www.rcraceboat.com/
    Dec 2010
    NY
    3,117
    very very hard material to cut,,,with what equipment I have ,,, I will not do it for customers I'have ruined a few props that way
    AZ
    8,010
    If you just have to use 1/4” cable, get one with a steped-down stub shaft. I would NOT drill out a prop, especially for high rpm SAW-type running.
    https://www.offshoreelectrics.com/pr...?prod=ose-1290
    Apr 2018
    OZ
    276
    HMmmmmmm.......
    Apr 2018
    OZ
    276
    I tried this and the end snapped off
    But not with the OSE as per link you supplied, thanks
    Apr 2018
    OZ
    276
    Quote Originally Posted by dasboata View Post
    But if possible, would the hub be ok ?
    Apr 2018
    OZ
    276
    Quote Originally Posted by larryrose11 View Post
    Thanks for your input
    Ga
    5,267
    Quote Originally Posted by Speedfreek View Post
    Been there done that..
    Did you put dog on the 3/16" stub? If so try it again and use a 1/4" dog.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Apr 2018
    OZ
    276
    Quote Originally Posted by Doug Smock View Post
    Not quite sure what you mean ?
    Using a 1/4 stub now will not go back to 3/16 stub with my setup.
    Ga
    5,267
    I was going by your post #6.
    I have broken the stub off a step down cable using a 3/16"dog. If you decide to go with the cable Fluid linked to consider using a 1/4" dog. While it is still possible to break the stub off (although I haven't) it is less likely since you won't be removing material from the 3/16 portion of the stub for the flat for the dog.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Apr 2018
    OZ
    276
    Yea that looks like a good shaft, i don't like the one piece one's that are machined down the two pieces ones appear stronger no weak point.
    might need to get smaller ID bearings In my drives to run these.
    The problem i have is that when i just want to have some fun and run a smaller prop there is no prop in 1/4 , and i don't trust 3/16 dog Any more with the torque these motors have.....
    Dec 2010
    NY
    3,117
    Jay already told you no The hub would be to thin I don't suggest it at all what prop anyway ?
    Jan 2016
    1,464
    After all the advice from very experienced people, those who have tried and also from dasboata, the prop guru, it's not advisable to do it. . . then perhaps he needs to find out for himself and go ahead and do it. . .Maybe he will be successful and we can all learn something new!. . .It's like telling a driver not to go through a red light as you might get caught and get a ticket . . .even worse get into an accident. So the driver does it a couple of times and gets away with it, finally on the third time he goes through the red light he gets hit by another car. . .the results are devastating, not just a ticket but perhaps lives lost. I apologize for the very harsh analogy but same principle.. .take the advice and save yourself the trouble. I too have tried it with no success as I ruined the prop before I could even put it on and break it during use. ..
    Jun 2010
    Mi
    738
    Using a 1/4 drive dog is a brilliant idea.
    This puts all the stress on the outer diameter, and is not transferred through the step down.
    I can't say for sure, but I'm willing to bet that the step down has a square corners at the step, which will lead to stress concentrations.
    Going with the 1/4 drive dog eliminates all of that. That would be a much more robust setup.
  16. #16
    Apr 2018
    OZ
    276
    Thanks , X57
  17. #17
    Apr 2018
    OZ
    276
    Exactly, thanks.
  18. #18
    Apr 2018
    OZ
    276
    Quote Originally Posted by Bp9145 View Post
    Thanks ,but I needed to here it from a prop guy
  19. #19
    Mar 2011
    BC
    7,629
    I’ve been running like this for a number of years. I have not broke a shaft. I have run cut down 457’s on this setup and mangled a couple props due to debris in the water. No broken shafts.
  20. #20
    Dec 2010
    NY
    3,117
    Hey I have a ABC 1/4" shaft 3 blade very similar specs if your interested
  21. #21
    Apr 2018
    OZ
    276
    Sweet
  22. #22
    Apr 2018
    OZ
    276
    Not a real fan of 3 blades , I have a Mystic 138 so would need a set of CR .....
    Do you have em in a two blade CR 1/4 ?
  23. #23
    Dec 2010
    NY
    3,117
    Ok I like 2 blades on cats anyway !!!
  24. #24
    Apr 2018
    OZ
    276
    What can you recommend in a two blade in a 1/4 Shaft ABC, and a little more aggressive then a Octura X57 ?
    Need CR too !
  25. #25
    Dec 2010
    NY
    3,117
    Need CR too !
    Ask your prop guy ????
  26. #26
    Dec 2010
    NY
    3,117
    [QUOTE=Speedfreek;733986]What can you recommend in a two blade in a 1/4 Shaft ABC, and a little more aggressive then a Octura X57 ?
    Need CR too !
    [/Q 2214 2215 ish
  27. #27
    Apr 2018
    OZ
    276
    [QUOTE=dasboata;733996]
    Need CR too !
    [/Q 2214 2215 ish
    I don't know the specs on ABC props I don't have a chart on them my ESC was Luke warm with a X57 108 mph !
  28. #28
    Apr 2018
    OZ
    276
    Here is the problem with the OSE shaft for me, mine is 5 1/2 inch before the flex OSE one is 4 inch.
    It will not work with my drives
    Mine , my bearings are at about 2 and 5 and it's 8mm thick shaft.
    OSE , 3/16 to 1/4
