Results 1 to 10 of 10
Thread: Little insight as to what may have happened?
    Apr 2016
    34
    Default Little insight as to what may have happened?
    We were filming with a Motly Crew and go pro, and the boat lost power randomly upon inspection both blades were clean broken off
    This is what we ended up capturing which i thought came out kinda cool:
    https://www.instagram.com/p/BvbtyghBBkd/
    Suggestions on a replacement prop?
    Apr 2016
    34
    guy at lhs said that was normal for the plastic props lol....
    so i picked up a metal x440 octua and a few plastic spares....
    Dec 2015
    La
    550
    Seen that happen on the been, almost stuck in my grandson's leg . No plastic
    maybe a rescue boat. Anyway have fun.
    Apr 2016
    34
    what?
    Dec 2015
    La
    550
    Yes bench testing a boat before we left and about half throttle it broke off.
    Apr 2016
    34
    ah!... yea LHS guy was not phased by it, said it happens to plastic props and to upgrade to metal one
    4,116
    I wouldn't run that Octura prop raw (straight out of the package). They need to be balanced at a minimum to help prevent an imbalance and wearing out your strut bearing, and sharpening will improve performance. If you're not looking to spend a lot of money on props, but want an upgrade over plastic, you can get CNC aluminum props or Graupner Carbon (plastic composite) props inexpensively from OSE in that size. Neither needs to be balanced or sharpened.
    Apr 2016
    34
    nice i will check it out. I have balanced multi rotor props etc... i assume it is similar, but you just remove material instead of adding?
    Apr 2016
    34
    which would be a similar graupner prop to the x440?
    Jun 2010
    Mi
    738
