Results 1 to 4 of 4
Thread: Alien Power ESC USB driver problems
    Mar 2019
    AA
    2
    Exclamation Alien Power ESC USB driver problems
    Hello,
    I recently bought an ESC from Alien Power Systems. It is the model 24S 300A. However, I cannot program it with the USB because I cannot install the Windows drivers for the USB. Alien Power recommends the driver Prolific USB to COMM. Firstly, I installed the 2018 version. I seemed to work, but the COMM port is connecting and disconnecting all the time, and it is impossible to make the software from Alien work. I found on the net that old version from the driver may work, but anytime I try to install another version of the driver the installation process fails giving exit code 10.
    I think I am not the only one with this problem, has somebody already solved it?
    Thanks.
    What Windows operating system are you using?
    Mar 2019
    AA
    2
    I tried Windows 10 and Windows 7. In both I get the same results.
    May 2014
    le
    58
    Quote Originally Posted by fredy View Post
    Hello,
    Thanks.
    This was reply from Bruno when I asked if esc was ballache with prolific and windows 10 when my esc arrived tried it as mentioned in pic, worked 1st time
    Sent from my G3121 using Tapatalk
Tags for this Thread
