Page 1 of 2 12 LastLast
Results 1 to 30 of 44
Thread: LiPo thoughts
    WI
    992
    Default LiPo thoughts
    in the past month(or so) I've seen a number of folks complaining about their lipos not living up to their expectations etc. etc., well before the beer gets too watered down lets see what we are getting for our hard earned cash. for a 2s2p setup comprised of 4000mah cells we get; 6000mah of usable power that comes in a package that weighs roughly 13 oz,. I've been told that they deliver like an 8cell nimh pack(weight 18 oz.) for voltage. for amps at a sustainable level of 26c(13c per pack) thats over 100 amps for over 3 minutes! maybe its not the 'killer' 200-300 amp packs some folks think they want, but I think I can live with it.
    Nj
    4,735
    OH my god LIPOS...Did you know they can explode with out warning and level a city block!!!! Bad bad bad lipos. I figuered I'd get that right out of the way in this thread before token drama post.
    WI
    992
    LOL you noticed that I very carefully mentioned no names, or brand names, or how some folks have been having er shall we say 'technical difficulties' with an older battey tech...:). just wanted to point out that even with derating them to more realistic levels, LiPo's represent an advance in power systems.
    KY
    1,511
    It all depends on what your doing. I have heard that some professional N2 mono setups are pulling 80 constant amps, in this case you need 10,000mah and 20C. Figure out how many amps your going to pull in a constant and go from there.
    30 amps needs a 50 to 60 amp constant LiPoly pack to last a long time. I look forward to hooking up the DPR on my Super Vee and see what it does. I'll then test some LiPoly in it. I think everyone needs to parallel in order to keep from over discharging their packs.
    thanks,
    Steve
    Nj
    4,735
    I look forward to hookin it up in mine also:D
    WI
    992
    last graph I saw of a sv amp draw had peaks of roughly 60amps was averaging 35-40amps(iirc)
    KY
    1,511
    If it peaks 60 amps, my 12C packs will be pushed even in parallel. You have to remember though that watts = voltage x current, the higher the voltage the lower the current levels needed. 14.8V of LiPoly should be better than 14.4V of NIMH
    7,279
    I'll be needing some soon for my V24 mod running a LMT 3080, I'll be looking for around 37V, 10,000 mAh .
    KY
    1,511
    Send me an e-mail and I'll get you a quote if your interested. sales@battlepack.com
    nc
    792
    I will let you know next week... have a few 3600 lipos coming from Steve/BattlePack. I got my pencil out and did some figuring. His 3600
    12cConstant/16c bursts lipos should be fine. If I had a charger that could charge 4 cells I would have went with 2 of his 14.8 volt pack and would have enough juice for a long long time. Since my charger only will do a 3 cell lipo I got the 7.4. I really want to see a set of lipos in the white boat. Next week I will post some more info. He mentioned that a low volt cutout, not sure if the SV ESC has one or not so I will guage the run time gradually to see how long I can run on the pack without discharging it to low.
    Nj
    4,735
    Buy a stand alon voltage cut off. I'm almost posotive the SV ESC don't have one.
    7,279
    The SV27 speed controller does NOT have a LiPo cuttoff.
    WI
    992
    oops my bad. data log was for an h & m viper running a super vee motor and esc.
    thread here http://www.rcgroups.com/forums/showthread.php?t=633493
    rex
    KY
    1,511
    Default Yes
    Yes, we know that......
    7,279
    BattlePack;
    I sent you an E-Mail here for a quote , when you get a chance , I'd appreciate it .
    nc
    792
    Would this be it? or something differnt. Tell me more I catch on quick..sorry for all the questions
    http://www2.towerhobbies.com/cgi-bin...?&I=LXPGM8&P=7
    Nj
    4,735
    Mr BattlePack sir... ..Did you ever order any of the cut offs? I remember you posted one a month or so ago.
    KY
    1,511
    Default Yes...
    I sent you an e-mail back....
    BattlePack;
    7,279
    Have not rec'd it yet
    KY
    1,511
    PM sent, not sure why e-mail did not work
    KY
    1,511
    Default Not yet...
    No I have not, I was planning on some capacity test runs, but I should get one.
    Quote Originally Posted by SJFE View Post
    KY
    1,511
    Someone asked me a question using a PM.....and I'll share the answer.
    You can use a Power Supply to charge liPoly packs, however, it must be the following.
    4.2V per cell and 1C Max current rate.
    example
    A 7.4V 4,000mah pack would need a 8.4V, 4 amp switching power supply. As the voltage gets close to 8.4V, the current rate drops. This is how it works.
    IT MUST BE SWITCHING!!!!!!!!
    nc
    792
    Here is a page from the MRC977 Op manual. I posted it for 2 reasons one is so you can see how it says to charge Lipo's since were on the subject.
    The other reason is Can some explain to me the paragraph E, on telling capacity. I dont understand it. If you know please use a example of a 4500 MAH battery pack
    KY
    1,511
    Sounds like a discharge of 1/5 amps at the end or C/5
    KY
    1,511
    What would be good is for Pros and non pros to share LiPoly setups with everyone and make a sticky thread that everyone could read. I know that we have Pros here and I wish they would share more info for everyone. By pros I mean racers that travel and compete on a national level.
    thanks,
    Steve
    NJ
    1,322
    Hi i have the 977 you do a discharge and then charge to show capacity ..but i don't think this is 100% acurate...also some guy's don't like the 977 because they say it don't charge lipos in the standard way of consistant current consistant voltage (cc/cv) But many use it and have no problems i charged a few lipos on mine and 2 at one time on it and it never gave me a problem.
    But i also have the Ice charger and it has cc/cv lipo charge mode and i mostly charge lipos on it and i never had a problem with the ICE to.
    WWW.PPRSLOTS.COM
    nc
    792
    Asked MRC about the Capacity check. Basically discharge the packs and charge them to 120-125 then, take the battery MAH capacity divide it by 5 then discharge at theat rate. So a 4500 mah battery divided by 5 comes out to 900 so it would be discharged at .9 amps. It sounds logical now but I reread that paragraph many times and it makes sense now but didnt last night.
    Nj
    4,735
    Well you just asked...Lets see who offers up the information. I would be shocked if some one who is racing and winning tell the potential competition how to level the playing field. But stranger things have happened. One thing we may have to take into is there may not be the "right" setup yet. There arent even and district wide races even posted in #1 yet. As a matter of fact the electric schedule was listed as "TBD" and now is missing from the page all together. One more reason I am not bothering with any events this summer.
    nc
    792
    Last night I pulled out my little Lipo packs from my planes. I have 2 packs one I suspected a long time ago it wasnt to good and the other was real good. I wanted to test out the MRC Superbrain 977 on Lipo's. I discharged both packs at 4 amps, the one I suspected was bad was... the other had 1724 MAH still in it after 5 months of sitting, there both 1800's. I set the 977 to charge the Lipos at .05c wich was .9 amps. The pack I suspected got warm so I took it off knowing it was bad. The other pack charged really nice. As it approched the 1800 mark I watched it charge for the last few min, watching the voltage. It shut off at 8.37 volts and had 1867MAH. I was impressed for the first charge of Lipos. Just for kicks I discharged that pack again and tha pack held really high(good) voltage right up till the last few MAH's.
    KY
    1,511
    Store LiPoly at 50-70% charged capacity, not 100%
