Results 1 to 4 of 4
Thread: Zippkits/Vbox on 16 cylinders
    Sep 2011
    ca
    164
    Default Zippkits/Vbox on 16 cylinders
    Well sort of. A Tp 5870 will be placed underneath.
    https://www.rcgalleri.dk/fotoalbum/t...ackerbox__vbox
    Jan 2019
    J
    49
    Looks good so far.
    Are those V8s in matching scale with the boat?
    Og så på dansk :)
    Ser godt ud indtil videre.
    Er de V8ere i samme skala som båden?
    Mvh. Frank
    Sep 2011
    ca
    164
    No they are 1/6 scale. I think the 46" vbox is considered a 1/4. But I would not be able to fit two of these in the hull, and if.. They would stick out to high..Tomorow I will take of the two black squares at the buttom. That will lower them half an inch. And I will see how I can make the lit so that the motors not just stand on top of it.
    Each motor is 493 gram / a pound with the squares. And measures 10x10 cm
    Det var sku da rart at se en dansker mere herinde...
    Mvh Sven
    Jan 2019
    J
    49
    Okay :)
    Anyways, should look cool. Its a very wide lady you got there... :)
    Im gonna follow your build.
    Du er rent faktisk den første dansker jeg er stødt på her inde.
    Lige bortset fra Kent fra CustomRCparts.
    Han må vel betegnes som en dansker i eksil helt der nede Down Under :D
