Results 1 to 7 of 7
Thread: leopard 1800kv timing
    Mar 2019
    ct
    2
    Default leopard 1800kv timing
    hey guys, just wondering what the timing should be set st on a leopard 1800kv motor, its in the traxxas spartan, with a swordfish pro 220 amp esc... ? also I am running the octura x445 prop if that makes a difference... thanks for any help guys! and yes I have been reading and I do know its a 4 pole "Y" wind motor... I was thinking 10 to 15? thanks again!
    Aug 2018
    Ky
    176
    Y wind 10- 15 timing is good.
    D wind 0 - 5 timing is good.
    2,910
    Quote Originally Posted by Rcforever32 View Post
    hey guys, just wondering what the timing should be set st on a leopard 1800kv motor, its a 4 pole "Y" wind motor... I was thinking 10 to 15? thanks again!
    Yes 10 to 15 degrees.
    Mar 2019
    ct
    2
    got it, thanks a lot eddie!!
    Dec 2014
    Ga
    544
    I run everything at 15* Y or D no difference.
    What is the reason that they should be run at different timings? And don't tell me "that's what I have always heard". That IS what I have always heard too, but not what I have always read.
    Steve Neu (surely you’ve “heard” of him) personally told me years ago to run Y motors with 10-15* and D motors 0-5*. The D motors do not require advance and too much timing will not give more power but will cause excessive heating. Too little timing on Y motors can cause excessive heat too, depending on the amp draw.
    Aug 2018
    Ky
    176
    100% correct!
