Results 1 to 19 of 19
Thread: OPINION on broken shaft
    Apr 2018
    OZ
    276
    Default OPINION on broken shaft
    2,728
    My guess is you ran an out of balance prop and/or prop nut and a crack propagated from the bottom left in picture 3 which allowed the shaft to bend and threw it further out of balance and quickly snapped the end off.
    Why are the step downs in shaft diameter there? Deleting them would make for a stronger shaft, or if they have to be there putting a raduis on there inside edges would spread out the stress load a little and make it a bit less failure prone.
    Aug 2010
    uk
    2,887
    What is the diameter of the step down & prop size on that shaft ? is it a 3/16" bore prop. As you are running very large powerfull TP 5850 motors on 12s, also as said a step down with no radius will also break easier. It also looked like there was not enough gap between the drive dog & the stinger to allow for flex wind up.
    Apr 2018
    OZ
    276
    Prop was a Andy brown ? I would think it would be balanced , Not my shafts and yes I agree that there should be a radius there
    Apr 2018
    OZ
    276
    Yea 3/16 , I have gone up to the next size now and I machined it so I can have more of a gap too.IMG-20190210-WA0007.jpg
    Aug 2015
    199
    to me looks like of scarring on that shaft (maybe more grease or more frequent greasing)
    Aug 2015
    199
    although after thinking about it, it would effect the flex shaft not where it broke, but still in all looks like it should have some grease in there
    7,629
    Quote Originally Posted by Johnc View Post
    That is from the bearing. BTW Speedfreak I run two bearings at each end to carry the load and last longer. Once they wear they could cause a wobble and that may happen quickly with only one bearing. Something I’ve been doing on the step down shafts is run a 1/4” drive dog which locks the prop. Just a theory but I haven’t had a stepdown shaft fail.
    Apr 2018
    OZ
    276
    This drive does have two bearings at the prop end , I have put the 1/4 drive in there now and I have allowed 6.4 mm of gap too where before it would not allow me to do that , that's what I think happend.
    Apr 2018
    OZ
    276
    Yep that's what I think
    Apr 2018
    OZ
    276
    So how much would you say a 1/4 drive flex approx 8 in long would contract on eceleration ?
    7,629
    Quote Originally Posted by Speedfreek View Post
    I would not think it would be much. 8” is fairly short. I know my 6” 3/16” have as little as 2mm gap with no issue. It’s all a matter of experimentation to find it. The little white thrust washers can help with this
    Apr 2018
    OZ
    276
    it's 7" long close enough i have 6mm gap now and 1/4 dog drive shaft , it better not brake now these props cost to much to loose.
    Jan 2019
    MO
    15
    whats it out of probably not balanced prop could be a bad bearing too
    Apr 2018
    OZ
    276
    Quote Originally Posted by MARK FORREST View Post
    Bearings are three runs old , prop was a Andy Brown.
    I might just put in oil-immersed sintered bronze bushings front and rear less headaches , expecialy in salt water...
    7,629
    End of season last year I stuck bushings in on the back of my HPR. I was having a hard time keeping bearings glued in for whatever reason. Plus... they aren’t $15 a pop every month and half.
    May 2009
    AB
    483
    I think I did the same thing on my 10s mono, 1/4” shaft stepped for 3/16” props, I had a 3/16” drive dog and that’s where it snapped. I’ve gone to a 1/4” dog now.
    Namba District 16
    Apr 2018
    OZ
    276
    The ones that I ordered have graphite dots in it to lube the shaft .s-l400.jpg
    Apr 2018
    OZ
    276
    Way to go for now.
    Going to centre drill on the lathe and press the prop shaft in that way it has no week point.....20190212_145641.jpg
