Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 151 to 180 of 244
Thread: PRO BOAT UL-19XR_Bashing a UL-19 into an outrigger...
  1. #151
    Jul 2018
    WI
    1,015
    Quote Originally Posted by Elekoz View Post
    awesome work! keep it up
    Thanks!
  2. #152
    Jul 2018
    WI
    1,015
    I'm closing up the sponsons! I made a template for the inside sheets. I layed some extra glass for the end caps at the same time...
  3. #153
    Jul 2018
    WI
    1,015
    I made four more formers for the stainless steel turn fin block. There's one behind the SS block if you're counting.
    I put the original foam back in the sponsons.
    Notice I didn't tape the fiberglass sheets to the sponsons while epoxying them together. Rather I have them setting on flat boards with the sponsons just setting on them. So they don't pick up any uneven areas from all the bashing I did to them...
  4. #154
    Sep 2007
    Co
    3,915
    I have not been around much lately due to my bike accident, so I am catching up hear. I scanned and read lightly over all..... as to not eat a lot of time and get a general overview of processes you are doing.
    Great job! Love the thinking out side the box.
    I do not know if the epoxy has hardened enough yet. But to promote the hardening, paint and wax is used to keep the air away and support the chemical reaction. There is small amounts of wax in hardeners to begin with. But if mixes are off I will add a coat later. This is the reason sanding is needed between coats. I also did not see if you were waxing the molds either. Just some thoughts trying to help.
    Randy
    BBY Racing
  5. #155
    Jul 2018
    WI
    1,015
    Quote Originally Posted by RandyatBBY View Post
    Thanks for checking in. This is my first fiberglass project, so it's been a steep learning curve. So wax and paint seals epoxy, keeps the chemical reaction going. Hmmn. Everything I molded is cured now.
    And I've been sanding the epoxy. I knew to do that but didn't know why.
    I've been using contact paper to release my molds. Instead of wax paper. It stays in place. Also everything I molded was flat.
  6. #156
    Jul 2018
    WI
    1,015
    The sponsons are all buttoned up. The world's first Pro Boat outrigger sponsons! Hehe...
    Time for final filling and sanding. Then paint.
    So I'm gonna try to reuse the Pro Boat letters. Peel the stickers and store them on wax paper. But just in case, I made some templates. I'll paint them if I have to...
  7. #157
    Sep 2007
    Co
    3,915
    I use wax paper for light stuff found it wrinkles, so a roll last a log time. Sounds like you found something with the contact paper. I saw that the other day on DIY using shelf paper. I use Buckshot bags to weight parts while gluing. I have mold's three sides of the sponson and do a wood backing. I have been testing flat sheet layups on well waxed glass with bagging and vacuum with great results to make sheets.
    What is the contact paper brand you are using?
    Randy
    BBY Racing
  8. #158
    Jul 2018
    WI
    1,015
    Here's the link, from Amazon...
    12" X 10ft Clear Transfer Paper... https://www.amazon.com/dp/B06XY8CLCG...p_mob_ap_share
  9. #159
    Sep 2007
    Co
    3,915
    Quote Originally Posted by sammyha View Post
    cool I will have to try some. Never too old to learn something new.
    Randy
    BBY Racing
  10. #160
    Sep 2007
    Co
    3,915
    After reading a bit it sort of reminds me of the frisket paper I cut on my vinyl cutter for template painting.
    Randy
    BBY Racing
  11. #161
    Jul 2018
    WI
    1,015
    It's called contact paper, but yes, it's more like a vinyl. It doesn't fish eye, and it releases.
  12. #162
    Jul 2018
    WI
    1,015
    This should be able to run with the big dogs...
  13. #163
    9,402
    Looking very impressive. Very intimidating size and look. Glad I don't run that class in your area, lol...
    If that's a kitchen, you must be single or you have a very accommodating partner.
  14. #164
    Jul 2018
    HI
    174
    Hope your recovery is going well!
    Interesting...and the epoxy doesn't stick to it? Typically that is used for placing vinyl cut stickers on the surface. I use transfer paper with my vinyl cutter to pre-cut masks for my rc cars for airbrushing. The transfer paper bends better than transfer tape so it is easier to get it around the complex curves of an rc car body...However you can feel the fibers so I doubt transfer paper would work all that well for epoxy.
  15. #165
    Sep 2007
    Co
    3,915
    I bought some of the contact paper to day thanks for the tip. I am going to warp a buck in it and see if it will work to make a mold.
    Now you need to paint and do your graphics.
    Randy
    BBY Racing
  16. #166
    Jul 2018
    WI
    1,015
    The stickers came off in great shape. Started one corner slipping an exacto knife under it, then a slow steady pull.
    Doing a body chop makes for a lot of filling and sanding on the seams. I'm done filling and rough sanding on the tub. Still needs a final wet sending. I radiused all the corners...
  17. #167
    Jul 2018
    WI
    1,015
    I'm getting there on the sponsons. Wet sanding all the factory paint off. I want good adhesion to the fiberglass with the Klass Kote epoxy paint.
    Hopefully start painting this weekend...
  18. #168
    7,633
    That is looking awesome. One of a kind and class all the way! Can’t wait to see it painted
  19. #169
    Jul 2018
    WI
    1,015
    Thanks. I'm going to spray this one. Going to try the Preval spray system. Amazon already delivered the goods to my door...
  20. #170
    Jul 2018
    WI
    1,015
    I started painting today. Here's my setup...
  21. #171
    Jul 2018
    WI
    1,015
    Check out this video. It covers what I did and how the Preval sprayer worked out...
    https://youtu.be/4jh0XJLWrIo
  22. #172
    Jul 2018
    WI
    1,015
    Here you are, a whole lot of work to get to this point...
    https://youtu.be/rIOd36Vqk5s
  23. #173
    Oct 2018
    Az
    38
    Looks great, Did you get the clear coat also?
    I have power tool's, it will fit
  24. #174
    Jul 2018
    WI
    1,015
    Quote Originally Posted by oldbikerarlo View Post
    I didn't get Klass Kote clear, but I'll spray a coat of finishing resin on it. Here's what I did, after I wet sanded the indigo blue Klass Kote.
    I had a decision to make. Go with a unique color that didn't match, or spray it with Pactra True Pearl. I sprayed the last coat with that from spray cans. So yes, it needs a clear coat still...
  25. #175
    Jul 2018
    HI
    174
    How close was the color match? A friend has a UL-19 that is going to need some repainting soon. Did you end up using the Pactra True Pearl?
  26. #176
    Jul 2018
    WI
    1,015
    Quote Originally Posted by InspGadgt View Post
    Yes. The Indigo Blue Klass Kote was too purple looking. The Pactro True Pearl is very close, almost a perfect match.
  27. #177
    Jul 2018
    HI
    174
  28. #178
    Jul 2018
    WI
    1,015
    One thing to know about that paint. It's not tough like epoxy paint. I sprayed two coats of clear over it. I'll put up some pictures after I get the stickers back on...
  29. #179
    Jul 2018
    WI
    1,015
    There's a never ending amount of work to building boats. We all should call the RTR companies up and thank them for what they produce. Or at the very least send a text...
    I got the stand built for the UL19XR.
    I used the Preval spray system to spray it with yellow Klass Kote. Such a handy gun to have around...
  30. #180
    9,402
    I'm interested in the Preval system. I wait to see your results.
