Results 1 to 5 of 5
Thread: Has anyone toyed with this?
    Aug 2018
    VA
    64
    Default Has anyone toyed with this?
    A better building material? I've been attempting to reinforce a 25.5 inch ABS hull with 3/16 ply. It weighed approximately 12 ounces before fiberglass reinforcement .Now it weighs in at 14.8 ounces. The 3/16 ply will add an additional 5.3 ounces. I feel as though this boat is getting too heavy from the get-go, as I am allowing weight for the motor, batts, electronics, etc. I've found a rather large piece of "foam core" it is foam sandwiched between plastic. Would this suite my needs? It seems to have the right flotation ,strength,and flexibility I so desire? Or would I be better off with some corrugated plastic? Thanks -Ken-
    Jan 2019
    WI
    29
    will the foam taken on water and dry very slow .. the water would have more weight then Plywood
    HE WHO DIES WITH THE MOST TOYS WINS
    Russ
    Aug 2018
    VA
    64
    That's a very good question, if the foam is dry and sealed at the seams, I can't imagine why it would be water logged after a 20 min run, can you? -Ken-
    2,912
    I have done 1/8" ply on a few ABS hulls years ago.
    With the power we have now with brushless and Lipos, the extra weight will not hurt the set up.
    Feb 2018
    PA
    330
    Actually 1/8 birch Aircraft ply is quite strong...glassed or epoxed in...have used it for years also....
