Results 1 to 14 of 14
Thread: -Proboat Miss Elam Full Rebuild-
    Jan 2017
    OH
    77
    Default -Proboat Miss Elam Full Rebuild-
    Getting closer to inlay time, already took out waterproof tub, started by getting rid of the wood mounts and stock strut and stock drive system as it is garbage and stock strut is non adjustable. Hull is very flimsy next step is to inlay and strengthen before new motor mount and drive system. First full rebuild that I'm doing so taking time to do it right, if anyone wants to follow and give tips or tricks along the way feel free :)
    Dec 2015
    La
    550
    Looking good. How long is this boat.
    Jan 2017
    OH
    77
    Quote Originally Posted by Beaux View Post
    Length is 27"
    Jan 2017
    OH
    77
    Some more parts came in today! Going to be getting ready for inlay and mounting stuffing tube and motor!
    Jul 2016
    4,100
    Wow, the final brushless version of that hull is certainly much easier to work on compared to the narrow tunnel in the original boats. You've got lots of room.
    Jan 2017
    OH
    77
    Yea it doesn't seem bad at all. The only thing is bolting on the new strut in back is gonna take a lot of patience since its so tight to get your fingers in
    Jul 2016
    4,100
    Quote Originally Posted by Mbires12 View Post
    You should see my hull, it's why I keep putting it off
    Aug 2008
    CO
    7,080
    When I did the one Ryan has, I had good luck sticking the motor as far forward as possible.
    That FE version has the weight way too far back for anything beyond the 40s. I’d be trying to get the cog to within 1” behind the trailing edge of the sponson.
    "Look good doin' it"
    See the fleet
    Jan 2017
    OH
    77
    Quote Originally Posted by Jesse J View Post
    Thanks for the tip! I ran the stock setup when I got it a couple months ago and I noticed that a bit. I figured a new strut that you can adjust vs the stock one will help that too.
    Jan 2017
    OH
    77
    2 Layers of Carbon fiber inlay just put in i think it came out decent for my first time
    Jan 2017
    OH
    77
    So i got everything ready to epoxy the motor mount and brass tube i was just wondering if the stuff i picked up will work, its jb weld 2 part 4400 psi clear epoxy, i plan on doing the o-ring method for a clean look if anyone has tips let me know!
    Jul 2016
    4,100
    Sand the attachment points both on the hull, the mount and the stuffing tube for better adhesion. I've also been sleeving my stuffing tubes where they pass through the floor with a small section of brass one size larger. About 1.5 to 2 inches long depending on the angle.
    Jan 2017
    OH
    77
    I pretty much got it all wrapped up just got to mount servo and put my RX in and shrink wrap the strut and paint the bottom of the hull and stuffing tube. I think it turned out well! What do you guys think?
    Jul 2016
    4,100
    Very clean. Nice work with the epoxy. I would replumb your motor water jacket so that the water enters at the rear barb, and exits through the forward barb. Clock the jacket so that the forward barb is as close to the 12:00 position as possible.
