Results 1 to 24 of 24
Thread: M/l boatworks 1/10 scale hydroplane build 121
    Nov 2018
    27
    Default M/l boatworks 1/10 scale hydroplane build 121
    image.jpeg hi there this is how far I am in this build its kit 121. I have been using smug mug pics.of kit 103. I am at a critical point as to what to do next, should I epoxy all skins and ribs ? I have carbon fiber to put in the engine well any sugestions would be of tremendous help I am a new to this sport. Thank you ron
    Wa
    5,905
    Have you sealed anything of what you have built yet?
    Sent from my Moto G (4) using Tapatalk
    Billy Graham
    Nov 2018
    27
    Should I seal the inside now and with epoxy?
    Wa
    5,905
    it is a lot easier now that to wait until after putting the decks on. You will never get it totally sealed after putting the decks on.
    Billy Graham
    Nov 2018
    27
    Ok great I will do that, should I cover everything or just the joints ? And thanks for the help
    Aug 2008
    7,080
    The drier the wood stays (sealing everything) the less the tendency to warp.
    "Look good doin' it"
    See the fleet
    Nov 2018
    27
    When you. Say seal everything is that in 2 part epoxy ? Sorry but I am a newbe have just been going on pictures I have found, not a lot of information out there .
    Jun 2012
    ny
    1,135
    Quote Originally Posted by RON F View Post
    I use west systems epoxy it's a 2 part resin and hardener. You can buy it in a kit on Ebay comes with pumps 1 pump resin 1 pump hardener mix and ready to go you don't have the hassle of measuring. I coat everything except center section b 4I put skins on I also use fiberglass cloth and fit pieces in then take back out and use elmers spray glue inside boat to hold cloth in place then put cloth back in and coat with epoxy mix.
    3,112
    Morning Ron,
    Yes, what the other are recommending is correct. In ANY boat or boating application you want to seal ALL bare wood surfaces with a 2 part epoxy. This also includes any exposed wood edges such as the lighten hole cutouts (end grain). Those can be frustrating to coat well with epoxy and in many cases soak up the most epoxy. For your application, I would suggest using something called a “Finishing Resin” similar to this.
    https://www.offshoreelectrics.com/pr...p?prod=hh-pt40
    Finishing Resin is slightly different than 5 or 30 minute epoxy as it is more viscous (more runny). This helps with a couple of things.
    1. It much easier to spread around quickly without leaving large quantities in one place (no pools or “globs”).
    2. The thinner stuff should soak into the bare wood better.
    3. Taking extra care to coat the joints could possibly strengthen the entire boat.
    Like the others have mentioned coating/sealing the INSIDE of the hull should be done just before your step of gluing on the top skins. You asked the question at the right time! As for this process of coating EVERYTHING in epoxy, there are many ways to get this done and none of them are quick if done right. Here are a couple of Tips:
    1. Mix epoxy in batches and do sections of the hull at a time. Think of it this way, if you mix up a large quantity of epoxy the chances are pretty good the epoxy is going to start to harden (kick off) before you can use is all.
    2. Most common method of application is using an acid brush. The bigger and flatter the area is the larger the brush I use. The smaller the surface area, joints, end grain, nooks, and crannies the smaller brushes work better. Another method I’ve used is taking an old Credit Card or a business card and use it to spread or squeegee access epoxy around leaving a very thin layer. Kinda like icing a cake. However, this is more affective on larger, flat surfaces.
    3. Once you have a fresh coating let the wet epoxy “soak” into the wood for 15-30 min. The length of time will largely depend on the pot life of the epoxy and your working environment. After the soak time, I will go back using a disposable foam tipped craft paint brush, and re-level or spread out all of the residual epoxy. What this step does is minimize puddles of epoxy building up in area where the wood is already saturated or hasn’t soaked up the epoxy completely. Another option is to take cheap paper toweling and simply wipe the entire area and let the paper toweling soak up the excess epoxy.
    Personally, I go thru this process twice and is why I like using the foam tipped brush. For the second coat the process is exactly the same; only while still wet (no wait time) I use the foam brush (trying not to apply a great deal of pressure) and level all wetted surfaces. The objective is to produce a THIN layer to protect the wood from water/moisture.
    Hope this helps!
    Mike Ball
    Nov 2018
    27
    Thanks Mike I will do just that I was wondering what type of brush to use as a paint brush is way too soft an acid brush is a great idea and my epoxy is too thick and I'll get some finishing resin
    thanks again
    Mar 2008
    974
    You can also thin epoxy using denatured alcohol if you already have that and don't have any finishing resin. Put a little in the epoxy and mix it up good and you now have runny resin for coating.
    Nov 2018
    27
    Thanks I'll try it my two part epoxy is bob smith slow cure it's pretty thick
    Mar 2008
    974
    Yes that will work fine.
    Nov 2008
    Ql
    3,169
    I prefer to use fiberglass epoxy resin, as suggested by others, rather than thinned down epoxy adhesive.
    But don't forget to give the underside of the decks a coat too, before you glue them on.
    Also add some foam blocks into all those compartments for buoyancy if the hull is breached in an accident.
    I also like to add some extra wood around the nose of my builds to give a bit more surface area for the top skin to bond to.
    Here's a pic that shows the extra wood.
    Nov 2018
    27
    Hi There the foam for buoyancy, good idea but can I use foamofil ? Or is the foam somthing special?
    Jun 2012
    ny
    1,135
    Ron, what I use is green foam board you can get a 2ft. X 2ft piece at Lowes for cheap. I ut to fit in each space under decking. Cut to shape fill to top however pieces you need and use a jack saw blade to level to top works perfect in my own opinion
    Nov 2018
    27
    Yup I'll do that, it's probably better foam than fomofil too
    Nov 2008
    Ql
    3,169
    Hi Ron.
    I used 2 part eco foam in that pic. But in my last few builds I have just been using that white coolite packing foam. Like in the pic below. But any lightweight foam board will do.
    Expanding foam can cause problems by expanding more after the decks are added on. And sometimes shrinking and sucking in the skins & ridepads, leaving hollows between the framework. That has happened to me.
    Here's a pic with the white packing foam.
    Nov 2018
    27
    Hi there do you glue it in or its just held in once the top deck goes on?
    Jun 2012
    ny
    1,135
    I don't glue mine I just pack it in tight
    Nov 2018
    27
    Hi there
    I am waiting for some finishing epoxy to show up I have cut foam to fit and should soon be ready for the top decks, do you use a thin paper board to make patterns for the top decking?
    Nov 2008
    Ql
    3,169
    I simply lay a piece of butchers paper over the frames of the panel I want, & crease the paper along the edges of the chines, frames, stringers etc.
    Then draw it a bit bigger and cut it out. Mark it out on the ply & then cut & trim to suit.
    Here's what I mean with the paper & the creases.
    Nov 2018
    27
    Ok good idea I will do it that way thank you. This boat, a vintage 60s hydroplane, I Plan to run it in a club, up in the pacific n.w (classic thunder) in a vintage class, it's supposed to go counter clockwise, what rudder assembly would you recommend? I got in on a club buy and have a scorpion brushless motor coming for it but i have no internals other than that so far.
    Regards ron
    Nov 2008
    Ql
    3,169
    If you are going to race it in a club, there are certain rules governing strut,motor, turn fin etc. As I've never set up a left turning 1/10 scale hydro, I cant offer any definitive advice.
    All I can say is that for the ones I've built, for right turning, I've used the Speedmaster 20 strut and rudder.
    The other guys on this thread, and forum, will be able to help you. Some of them race 1/10 scale.
    They'll chime in shortly, I'm sure.
