Results 1 to 3 of 3
Thread: 1000 Watt 12 Volt Power Supplies From Mojo Racing Products
    Sep 2010
    588
    Default 1000 Watt 12 Volt Power Supplies From Mojo Racing Products
    $62.99 each. Take an additional 10% off using coupon code PS10 at check out
    Click here to shop now!
    Maximum Performance 12 volt DC power supply by Mojo Racing Products. Take advantage of your high output battery charger's capability. This compact power supply packs a big punch with 75 Amps of current and 1000 watts of power as rated by HP. Power it with 220v AC power and get 1200 watts! 2 sets of standard 4mm DC output lugs lets you power two battery chargers at once. Built in cooling fan and air gap feet help keep the unit cool. No longer wrapped to help with heat dissipation. Includes 1 free light duty120v AC power cords. For high output dual port charging we strongly recommend up grading to the high amp power cord!
    75 amps of continuous charging current
    HP rated at 1000 watts maximum power output at 120 vdc supply
    4mm dual DC output lugs front mounted
    Compact size perfect for travel racing
    Free 120v AC light duty power cord
    Dimensions 1.6" tall x 3.5" wide x 9.5" long
    Weight:: 2.6 lbs
    * Note, end user should use safe charging practices. Always use grounded AC power cord and AC power receptacle! Mojo Racing Products LLC assumes no liability for usage of this product by end user.
    Bob Zola NAMBA 212
    2022 NAMBA Nationals FE High Points Champion
    Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
    9,401
    Hmmm, thats light...
    Shipping to Canada? could piggy back someone else's order.
    Sep 2010
    588
    See your PM
    Bob Zola NAMBA 212
