Results 1 to 4 of 4
Thread: Proboat Motor and Esc Combo
    Default Proboat Motor and Esc Combo
    *_*_*_*SOLD*_*_*_*
    Pulled out of a Proboat Miss Elam 1/12 hydro that I'm building up.
    Esc battery end has no terminals, can put 5.5mm bullets on for free if buyer wants.
    ---Specs on motor---
    Type:Brushless 6 Pole Inrunner Motor
    Bearings or Bushings:Two 5 x 11 x 5mm Bearings
    Voltage:10-21
    RPM/Volt (Kv):1500
    Continuous Current:45
    Speed Control:PRB3309
    Overall Diameter:36mm
    Shaft Diameter:5mm
    Shaft Length:18mm
    Overall Length:74mm
    ---Specs on esc---
    Forward:Yes
    Reverse:No
    Brake:Yes
    Continuous Maximum Current:45A
    Input Voltage:Minimum 10V, Maximum 21V
    Momentary Peak Current:55A
    BEC Voltage:5.8V
    50$ shipped for both
    Aug 2008
    CO
    5,806
    I’ll take it. No need for bullets
    "Look good doin' it"
    See the fleet
    Sounds good Jesse, Paypal is Mbires12@gmail.com
    Aug 2008
    CO
    5,806
    Thanks Michael, $$ sent
    See the fleet
Tags for this Thread
