Results 1 to 2 of 2
Thread: Temperature Guidance
    Dec 2018
    NY
    7
    Default Temperature Guidance
    New FE racer here. I have a P-Limited Mono. If I use a heat gun to take temp readings of the motor, ESC, and battery, is there a set of guidelines for when temps are in the “green”, “yellow” and “red” zones?
    Thanks,
    Mike
    Feb 2008
    GB
    2,727
    Motor green <60C, yellow <80C, red >100C.
    ESC there isn't really a full green, any heat above room temperature reduces the life of electronics, the cooler the better, yellow >60C, red >80C.
    LiPo yellowish green 20-40C, full green 40-50C, yellow 50-60C, red >60C (hard red with a police roadblock, as at over 60C there is serious likelihood of an unstoppable thermal runaway leading to a highly energetic fire), also yellow in use between 10-20C, red in use <10C, and red <0C whether in use or in storage.
