Results 1 to 12 of 12
Thread: My JAE33 FE
    Sep 2010
    10
    Default My JAE33 FE
    Here is where I'm at now. This is my second brushless FE build. Previous boats were mostly nitro. Motor is a TP3640 1935kv. It will run on 4s.
    Craig Mapstone
    Jun 2010
    Mi
    738
    Others here on the forum have run tp motors near their max voltage witth smallish props for the given hull to good success.
    He was running a 4060 1650kv, on 8S with an X646 prop.
    For your motor, max voltage 31V.
    Once you get more experience, 6S and a smallish prop could be an option for more speed.
    Here is the reference thread.
    https://forums.offshoreelectrics.com...s-enough-power
    Sep 2011
    ca
    164
    Nice build. I think you will have great fun with that setup. Good speed. Good runtime. just a question. How wide is the mid section ?
    Sep 2010
    10
    Quote Originally Posted by Nevs View Post
    I will have to check when I get home tonight. The tub is wider than the nitro JAE 21's I have. Plenty of room for batteries and such.
    Sep 2010
    10
    Outside width is 3.75". Tub walls are 1/8" thick ply.
    Sep 2011
    ca
    164
    Thank you very very much.
    Sep 2018
    So any pics of the end result love to see what paint job you went with.
    9,402
    Is there a specific reason to use ZPOxy to build this or is West Systems o.k. or too heavy????
    Z-Poxy Finishing Resin is easy to find and easier to mix, and cheaper for a few builds. West may be better quality, but Z-Poxy is fine.
    Sep 2010
    10
    Quote Originally Posted by RobCoba View Post
    Sorry for the delay... Ran the boat all spring, but 2 weeks ago, the drive shaft tube failed under the ski. So need to replace that, which means cutting the ski off I guess. First time I have had that problem. My 21 Zippkit JAE is several years old and has seen MANY races and crashes. But anyways, here is a pic I took just before it's maiden voyage. No special paint job. lol Cowl is painted yellow now.
    Why did you mount the rudder on the opposite side recommended in the manual!
    Sep 2010
    10
    Any drag the rudder creates will help counter the drag from the turn fin. It's small, but the JAE riggers turn awesome with the rudder on either side. I have built a .21, .45, .91, and a gas.
