Results 1 to 5 of 5
Thread: cutting 1/8" plywood in stead of lazer cutting- what can i use. Winter project.
    Mar 2014
    IA
    165
    Default cutting 1/8" plywood in stead of lazer cutting- what can i use. Winter project.
    Long title but might help with good replies. Project is making a Wild Thing during winter months, thanks for all replies! Have a good day!
    2,729
    Typically a fret saw or a scroll saw, but I think the wild thing is flat enough that you could probably use a hack saw or a band saw too.
    Mar 2014
    IA
    165
    Thank you!
    May 2009
    AB
    483
    I’ve used a jig saw with no problem to cut out parts roughly from a big sheet, then trim them with a scroll or bandsaw and then sand up to the lines. The best tool I’ve purchased is a Rigid oscillating sander if you plan on more builds it’s a time and elbow saver. :)
    Namba District 16
    Nov 2008
    Ql
    3,169
    I use a scroll saw for some of the tricky shapes. But a straight edge & a sharp knife for the straight lines work well. A palm plane & a sanding block are always useful too.
