Results 1 to 4 of 4
Thread: Strake Question for Catamaran Build
    Dec 2016
    Tx
    3
    Default Strake Question for Catamaran Build
    Good evening all,
    I am in the process of building my first cat, 34", and the plans I built from do not show any strakes. I was wondering if the strakes were omitted from the plan for a reason, or not. I am not a racer thus this boat will be for sport running with my grandson at the lake where we live.
    Do you cat drivers have strakes under your boats?
    Do I need strakes and if so, where is the recommended placement?
    Thanks all in advance,
    Mikey
    7,630
    Well if you are into a bit of reading I dug this up while trying to get more informed for an answer to your question.
    https://www.boatdesign.net/threads/c...-design.15072/
    Follow a few of the links around and it gets informative.
    But I don’t think my cats really have strokes so to speak. And not the dihedrals for sure.
    BTW, that’s a great looking hull you have there. Plans?
    Shawn
    Dec 2016
    Tx
    3
    Shawn
    Thanks for the link Shawn, interesting reading. The plans I have I dug up on the net called custom cat, see attached. I have found the same plan called different names but the custom cat plan was the cleanest so that's the one I used. It's a basic plan so one has to put some thought into the build. For instance, there are no patterns for the planking or decking, thus the question about the strakes. Also, I learned how to bend basswood on this build, what a life saver!!
    Thanks again for the positive comment and link.
    Mikey
    Attached Files Attached Files
    Aug 2008
    7,080
    Hi Mikey,
    Those plans are the original shocker cat, drawn up by “Lone Wolf”.
    I have built cats from those plans in sizes from 12”, 14”, 24”, 27, 34” and 36”.
    I took the plans into my drafting software and made some mods and have given them out freely since Shocker gave me his for free.
    About the strakes:
    My rev2 design 24” build originally had no strakes. It ran wet and too deep in the water. I then added balsa strips intended for trailing edges of airplanes and it made a world of difference.
    Look up my builds with key words “scratch cat” and you should find what I have done and get an idea of my mods.
    Hope this helps.
    Jesse
    "Look good doin' it"
    See the fleet
