Originally Posted by
Crash
If a guy runs a motor rated at. 3600 watts 1650kv and a guy runs a 6200 watt 1650kv does one draw more amps ? Does it make more power aka torque in same set up boat and prop and lipos same?
Power = Volts * Amps.
Voltage*Motor KV*efficency = Loaded RPM.
The prop is what determines the amp draw for a given setup.
For a given hull and prop, If the motors have the same KV and efficiency, then the amp draw will be the same. The motor power rating is what the motor is capable of producing.
