Results 1 to 5 of 5
Thread: New guy needs help
    Aug 2018
    WA
    8
    Default New guy needs help
    I now know now I have the wrong motor for my boat 7.5 lb, hydro, have a 3660/2726 KV, 3s parallel, is there any prop I could run with out a new motor? and more $$$, for new motor, I do not care how fast I go. I put on a new water cooling jacket on motor, as wires burned a little with a 42X55 prop. motor and ESC still working. Thank You
    Mar 2017
    VI
    371
    If wire are burning with a 4255 you may need a smaller prop too reduce amps even more. And too small of a prop may not be good as it may not plane.
    If they was a gear box available that would help.
    So this the challenge with a high kV motor.
    Aug 2018
    WA
    8
    I have used a 48/55, and a 42/ 1.3( 55) what size is next that i can try? Like the gear box idea too.
    Apr 2017
    MT
    155
    I would try a 40/1.4 or 38/1.4
    Mar 2017
    VI
    371
    To be honest I don't think you will have a decent performing boat with that 3660 2726kv motor.
    A bigger motor with a lower kV would be ideal. Like a 1300 to 1400kv 4082 or 4092. On 6s turning a prop between 45 and 47mm.
