Results 1 to 7 of 7
Thread: 40 series 10 S motor
    Oct 2015
    313
    Default 40 series 10 S motor
    hello ,
    can anyone recommend a 40 series 10s motor?
    I tried searching and didn't find much.
    thank you.
    Dan
    7,631
    Dan do you mean a 40mm like a TP 4050? What kind of running are you planning? I run the 1050 D wind on 12s but that is pretty high rpm. There is a 950kv too.
    Oct 2015
    313
    thanks.
    I was not looking at the charts for TP Motors rite. Now I see what your saying.
    With your 12s set up …. do you have data log on your ESC? I am curious, what kind of amps you draw and the max watt draw?
    My set up is the TP 4060 3y 1750kv on 8s (76 mph at 78% throttle....)
    having a 36 mono on 8s is a lot of fun, I imagine 10s would be more fun. I have the esc and lipos already, just would need a motor.
    what kind of boat you running?
    7,631
    I have those in a Fantasm (Zonda) https://youtu.be/-UQDIriKl1g
    I do have logs.
    I have been going HV on my stuff for a bit now. I also have this 40” twin on 8s with TP 4030 series @ 1180kv
    https://youtu.be/TkanhcQIe-I
    It runs about 9 mins on 8800mah
    7,631
    Oh and if you look up my ‘Ugly Cat’ build it will be a 10s boat. It is getting the 920kv 4050’s. Motors and Escs are next there
    Oct 2015
    313
    very nice boats .
    thanks
    7,631
    So you are just looking to change the setup in the current boat then?
