Results 1 to 29 of 29
Thread: Sonicwake 36 hits 64mph with dasboata prop!!
    Feb 2017
    na
    657
    Default My Sonicwake 36 from 54mph to 73mph!!
    First run on My new Pro Boat "Sonicwake" 36 self righting boat. The gps logger got 64mph and the gps devices got it at 63mph. This run was right out of the box except for a prop swap. https://www.youtube.com/watch?v=JEZs9EmC5P0&t=14s
    TFL Zonda (111mph), Miss Geico Zelos 36 (108mph), Zelos Twin 36 (90mph), Veles 29 (85.2mph), Miss Geico 29v3 (83.5mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17, Atlantic II Tug
    Jan 2016
    1,382
    I think this will be my 10yr old son's new boat. He loves green and almost all his boats, cars and drones came in green or i painted them green. So this one will definitely be on his Christmas list. Mark, looking forward to what you might do with this. . .probably set fastest run on all times with this in stock form as with your other two. . LOL
    Jun 2018
    la
    39
    What prop you used ?
    Feb 2018
    PA
    302
    MADRCER.....keep the info comming on this boat...I have one on order from OSE.....
    Dec 2010
    NY
    2,592
    looking good Mark get that boat to lay down a bit and make a full pass ,,you should be near 70 MPH good job man
    Feb 2017
    na
    657
    Thanks Chris! You got something coming your way I'll talk to you about later. I'm thinking it might get mid 60's to maybe 70mph once I put one of the good props on it. Got to tame her down a little though.
    Brian, Thanks and your son will love this boat!
    Kyoshosp2, I used a modified and reduced Octura prop that was from Chris.
    Will do 30nitro!
    Feb 2017
    na
    657
    Feb 2018
    PA
    302
    Quote Originally Posted by MADRCER View Post
    Nice pond... Just got my new sonic wake....not wet yet...did you change anything to set it up..other than prop...which I have...anything I should change or look for ? Keep us posted on any new runs.
    Feb 2017
    na
    657
    Quote Originally Posted by 30nitro View Post
    Thanks! I went over all bolts and screws and I added Loctite where needed and found the rudder mounting screws were a little loose. I took the strut bushing out and sanded a little on it so it would spin free and put a cable saver on the flex shaft. I did add a few drops of 3 in 1 oil on the hatch bolts and ran them in a couple of times to get the threads broken in and that's about it. Good luck with yours.
    Feb 2018
    PA
    302
    Working on mine as I type this....will use a flex saver..going over all nuts and bolts...rudder pivot a bit loose..? Mabe maiden it monday... weather permitting here in PA...
    Jun 2018
    la
    39
    The strut doesn’t appear to be adjustable . Anyone tried yet ?
    Aug 2010
    uk
    2,880
    Quote Originally Posted by kyoshosp2 View Post
    Raphael has spoke about this very thing, he suggests to remove the stuffing tube & anneal the tube so that the tube & strut can be moved easier by bending the tube a small amount to give either + or - adjustment on the strut.
    Jun 2018
    la
    39
    Think I’m gonna out a longer adjustable one from ose .. he said that would stabilize it at high speed to
    Feb 2018
    PA
    302
    Seems pretty stable with the stock one......but some adjustment would be nice.... I'm gonna try a little mod to the stock one first......
    Feb 2017
    na
    657
    Default My Pro Boat Sonicwake hits 69 stock!
    Here is my latest run of 69mphwith a prop from Chris Hoffmann (dasboata).. Rafael please have Horizon fix the "maps" compatibility issue for the Dynamite gps logger...They no longer display on them on the PC....
    https://www.youtube.com/watch?v=Cje_...ature=youtu.be
    Edit: The map portion is now somewhat working again so I have attached an updated photo from the data logger to show where the boat actually hit 69mph at which was right in front of the dock on the first pass.
    Sonicwake 36 69mph pic of datalog 10-16-18.jpg 69mph sonicwake.jpg sonicwake 69 pic 2.jpg
  16. #16
    Feb 2018
    PA
    302
    Oh crap..!!! Really wanted to see that vid...!! Mine's ready to splash.....
  17. #17
    Jun 2018
    la
    39
    That the new prop or original you had cut down ?
  18. #18
    Feb 2018
    PA
    302
    Here is my latest run of 69mph with a prop from Chris Hoffmann (dasboata).. Rafael please have Horizon fix the "maps" compatibility issue for the Dynamite gps logger...They no longer display on them on the PC.... https://www.youtube.com/watch?v=Cje_...ature=youtu.be
    Finally saw the vid.....totally awesome!! I' be happy with 65 out a mine....
  19. #19
    Feb 2017
    na
    657
    This is a new prop. I'll respect dasboata props and not give the info out publicly but if anyone wants to buy one from him I've told him what prop I used and he can modify yours like mine.
    Thanks for the comment! I appreciate it.
  20. #20
    Feb 2017
    na
    657
    Default My Pro Boat "Sonicwake" 36 hits 54mph 100% all stock!
  21. #21
    Feb 2017
    na
    657
    Default My "Super" Sonicwake 36 hits 71mph stock with dasboata prop!!
    I finally got my "Super" Sonicwake 36 into the 70+mph club! The gps logger got the boat at 71mph and the Gps device got the boat at 70.7mph. The little boy Dwayne came to fish with his family but his fishing pole never hit the water he was so interested in the Sonicwake..Lol!
    https://www.youtube.com/watch?v=mlhg8ESVuVQ&t=23s
  22. #22
    Feb 2018
    PA
    302
    Very well done...!!
  23. #23
    Jan 2018
    sj
    59
    Hi guys I just get my Sonicwake. I remove the flexshaft to add some grease. I wonder how to align the flexshaft all seems fixed. And also can't see how to adjust the strut ??
    What prop do you guys recommend whit stock electronics for little more speed.
  24. #24
    Feb 2017
    na
    657
    Congrats! Loosen the bolt that holds the strut in place and loosen the two screws that hold the stuffing tube in place inside the boat and move to the desired position then tighten everything back up.
    As for the prop a 45mm prop from dasboata will get you a little more speed over stock (he knows which one you'll need). Or step up to the "Super Sonic" prop from dasboata if you want to touch or get near 70mph with a decent setup.
  25. #25
    Jan 2018
    sj
    59
    Ok i take a look at strut. Im NOT so lucky i Can order props from Dashbota. I live in Danmark and shipping and import cost is extremly High so was thinking a 45 mm CNC prop but NOT sure if it Will overload ESC becurse AMP draw Will get to High . But i Think i Will just try it.
  26. #26
    Feb 2017
    na
    657
    Here's another quick run (in fun mode) No gps required...
    https://www.youtube.com/watch?v=Hqxc3uUk1Xc
  27. #27
    Feb 2017
    na
    657
    Default My "Super" Sonicwake hits 69.4mph
    Another test session today...69.4mph was the top speed today. I was setup for laps before this speed run and forgot to fully put the boat back into speed run trim, so I left a mph or so on the table and I know it but oh well. The speed may have been 71.xx mph if I was thinking properly...LOL!
    https://www.youtube.com/watch?v=kPEnauUWteY
  28. #28
    Feb 2017
    na
    657
    Default Sonicwake 36 hits 52mph with a 100% stock out of the box prop!
    My Sonicwake 36 100% Box stock (prop and all). It's a little long but Hopefully you will enjoy it. The "teaser run" at the beginning was with the stock prop as well. The rescue "nudge" scene was sped up because I couldn't see the boat in the glare. It finally self righted on it's on My batteries shifted in the flip and it was just enough to get my balance off and make it extremely slow to right. https://www.youtube.com/watch?v=yVwXywRdEvA
  29. #29
    Feb 2017
    na
    657
    If it ain't blowing over you ain't trying hard enough.... Sonicwake @ 73mph stock!!
