Page 1 of 2 12 LastLast
Results 1 to 30 of 38
Thread: TAMIYA Thrust Ball Bearing
Hybrid View
    Oct 2009
    FR
    2,096
    Default TAMIYA Thrust Ball Bearing
    I want to use this one piece Thrust Ball Bearing between 2 teflon washers in front of the propeller.
    Size is perferct 5mm x 11mm x 4mm.
    The two external parts and balls make one piece perfectly adjusted and very strong
    Jul 2015
    701
    A thrust bearing goes between the collet and motor mount.
    Oct 2009
    FR
    2,096
    Quote Originally Posted by Prodrvr View Post
    Sometimes, yes
    Feb 2008
    GB
    2,731
    Why the Teflon washers if you are using a thrust bearing? Is the brass part recessed behind the races faces,or will you have to concave the drive dog and strut slightly tomato sure it doesn't touch there?
    Oct 2009
    MI
    6,192
    A 5mm stub shaft? Where would you find a prop for that?
    I use that bearing on every spec boat but at the motor face. They do work well.
    Noisy person
    Sep 2007
    NC
    2,783
    You can use these on the strut end, but you will have to find a thin tube shim to center the 5mm thrust bearing on a 3/16" shaft.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Oct 2009
    MI
    6,192
    Probably depends on the strut too. You don't want a thrust bearing or a washer that's bigger around than the strut.
    Noisy person
    May 2017
    OK
    1,464
    It’s really important where the boat is being pushed at. Typically, it is not a good thing to push a boat from the strut or back. Ideally, pushing at the COG is the best and that’s why the thrust bearing is mostly mounted between the shaft coupler and the front motor face. Those thrust bearings won’t hold up to water lubrication for long. I have all my boats running this bearing at the motor. The proper spacing on the strut to prop hub is also important. The no-brainer, don’t want to worry about it spacing is the diameter of the flex shaft. I run it about 75% of that number. Some flex shafts wind up more than others, you got to learn that. I used the graphite washers at first in the space, then when I could see witness marks of it hitting gave me a good number.
    Oct 2009
    FR
    2,096
    Are you serious ???
    Pushing at the COG your boat will want to go Under the water ...
    Dec 2009
    LO
    30
    Quote Originally Posted by Alfa Spirit View Post
    Are you serious ???
    Alain, my friend
    The thrust on the COG of your boat will only have the effect of dropping it from its shelf ... LOL
    Did you at least drill a hole in the hull ?? I don't think so...
    cheers
    ON
    9,402
    Some H&M stubs are 5mm step down to 3/16".
    Jul 2015
    701
    Thrust bearings go between the collet and motor mount to save the motor bearings because they aren't designed for lateral loads. I've never seen a thrust bearing placed between the strut and prop. And what's up with pushing the boat at the CG? What?? WTH is that about? LOLOL
    May 2017
    OK
    1,464
    I’m talking about hydros... Go under water? Serious drugs are being used here. Do any of you ever think that any racing hydro with an inboard engine are pushed from the back? We go to great lengths to design thrust packages in racing hydros to get the push as close to the CG as possible. Huge effects in turning stability! Whether RC or full scale, the force vector diagram is the same.
    Jul 2018
    WI
    1,013
    Serious question. I want to learn. If it pushes close to the cg, behind the motor, then why does strut angle matter? It would be pushing thru the flex cable and at an angle up to the motor, if what you're saying is true. Then it would push the bow down, right?
    May 2017
    OK
    1,464
    Quote Originally Posted by sammyha View Post
    Serious question. I want to learn. If it pushes close to the cg, behind the motor, then why does strut angle matter? It would be pushing thru the flex cable and at an angle up to the motor. If what you're saying is true, then it would push the bow down, right?
    It depends where the transfer weight point is... Applies to all hulls. Think of a teeter-totter, the closer you push to the hinge point, the more the small length of the moment arm with its upward angle is swamped out. The overwhelming force vector becomes the lateral push... If your running SAW then as a Tyler states, it can be designed successfully from a rear pusher to a mid pusher. But on any boat, the positive/negative angle of the prop becomes much more reactive the further it is from the CG. It’s just Physics... I have to make boats turn at 180mph, full throttle down the straight, then turn the rudder. The push needs to be as neutral as possible to maintain a good ride characteristic. The Physics are identical to our full sized, 1600hp hydro and my 34” hydros. And even with a zero angle on the prop, there is STILL an angle being formed from the lower strut position up to the cord of the CG, which is the 3-dimensional balance point.
  16. #16
    Sep 2007
    NC
    2,783
    Many of the worlds fastest hydro's are pushed from the strut or a split between the strut and motor. Hulls have to be set-up differently depending on where they are pushing from. Not only FE, but many of the fastest nitro and gas boats also use square cables so they are not pushing on the engine even though they all have ball bearings in the engines and only plain thrust washers in the strut.
    The fastest 5 hydro's in the world all push off the strut using either a wire drive or square cable.
    Tyler Garrard
  17. #17
    Oct 2009
    MI
    6,192
    The only square drive I've seen up close leaked like a rain forest. Has to make for less friction loss in a stuffing tube.
    I used to build my wire drives with ball bearings. The last in the strut being a flanged stainless bearing with an extended inner race. Really really works well but failure is imminent. Especially if you turn a lot of laps. It's not an if. It's a when it fails. That flanged bearing really isn't made to do what I was asking of it. I got tired of them failing at the most inopportune moment. Like.....on race day.......during a heat. haha Plus I was spending $50+ on bearings every time.
    Doug Jr had a limited mono set up with a stainless thrust bearing and a stinger. That was maybe 4 years ago. Probably the 2014 nats. I could never understand what he was doing about the wind up from the flex. Hind sight, maybe he was running a square drive back then too.
    Noisy person
  18. #18
    Sep 2007
    NC
    2,783
    Square drives are tricky to seal, but not impossible. There are ways of completely sealing the drive-line to same level as a welded cable set-up. Just takes a little creativity. The pic of the P-hydro uses a double square cable. Hyperformance 5mm to .150 square coupler on the motor side and a 3.5cc outboard stub shaft setup on the strut. The cable is fully enclosed in the stuffing tube.
    I only use ball bearings in SAW boats were longevity is not a concern. The bearings also tend to be larger than what is typical in the common set-ups and bearings are often doubled up.
    I have run my Q mono with a 3mm wire drive for years now and it leaks a little, but it has been rock solid. I can get away with bushings in the strut because there is very little bend in the drive-line.
    Tyler Garrard
  19. #19
    Jul 2015
    701
    The OP is talking about using a thrust bearing...where did hydros come into the discussion?
  20. #20
    Jul 2018
    WI
    1,013
    To my way of thinking the bearing behind the motor only takes the thrust and transfers it thru the motor mounts to the hull. The strut directs the prop thrust cone. The strut is attached to the hull. So the thrust vector is transferred entirely thru the hull.
  21. #21
    May 2017
    OK
    1,464
    This is correct, but it all changes if the hub of the prop makes contact with the strut. I noticed it on my RC hydro because the stern started to jack up, there was a change in the ride characteristic. And an 1/8” flex winds up more that a 3/16” flex. I liked the idea of using a stub shaft and square drive in the flex and use a thrust roller bearing in between the prop/strut, but the force vector diagram I made up showed that I would lose turning stability.
  22. #22
    Jul 2018
    WI
    1,013
    Hmmn. Maybe the bearings held it more accurately and the result was something really was a bit off.
    We got a lot of hay down boys...
    Sooo... with the strut angled up slightly in the front, if you extend that line it will be somewhere between the 3 dimensional CG and the bottom of the sponsons. That's not necessarily downward thrust. The sweet spot will be somewhere between the 3 dimensional CG and the drag on the sponsons.
  23. #23
    May 2017
    OK
    1,464
    Ideally yes... but all of that can be brought into balance by how much air under the boat, the AOA of the sponsons and where the CG actually is. When the boat, like your UL-19, carves a corner, much better stability can be achieved by pushing close to the CG. If you ran you boat on a tether, where would you attach the cord for best performance? At the CG, and you would want your lateral driving force to be at the same point. You get it Sammya... If your just going straight then I think it matters much less. I carve corners... That’s where the fun is for me!
  24. #24
    Jul 2018
    WI
    1,013
    Thanks, great stuff there CraigP...
  25. #25
    May 2017
    OK
    1,464
    Terry, I thought about using a stack of wavy spring washers to take up the slack. The distance of the spring washers from min to max would be a distance greater than the flex windup. So the thrust bearing would move forward with the windup and the spring washers counteracted it... But the vector diagram I made indicated the better pushing point is at the motor, which is almost exactly on the CG cord. But it would have been a trick setup! I even located some C’bore tools to modify the end of the strut. That tooling went instead to getting the lip seal in the back of the strut to stop grease loss and prevent water from getting in the stuffing tube. I get about 20 runs before having to freshen up the grease, keeps me bloody fingers clean!
  26. #26
    Aug 2012
    ny
    1,359
    I use these on pretty much all of my boats between the strut and the drive dog, doesn't need to be perfect around but needs to "ABSORB THRUST" I didn't read a 1/4 of this post but you can use them on the shaft between strut and drive dog, I've been using them for years, I don't know why other than they look cool but I've never lost a cable because of one?
    We call ourselves the "Q"
  27. #27
    Jun 2009
    MI
    2,539
    Love the idea. In fact, I think I started the same thread a few years ago! Putting the thrust at the strut eliminates side load of the flex cable on the stuffing tube. I was never able to find a long enough 0.150 cable with a square end for sliding. 3/16" cables seem to be easy to find.
    Tyler - Where did you find that squared end 0.150 cable? Or is that just a short outboard cable?
  28. #28
    MI
    3,117
    Quote Originally Posted by Shooter View Post
    Pete,
    I have been running a .150 square/square set up in my PT Stealth for 3-4 years now.
  29. #29
    ON
    9,402
    Quote Originally Posted by longballlumber View Post
    Pete,
    How do you do lube jobs on a contained drive like that? How often?
  30. #30
    MI
    3,117
    *Flip the boat over loosen 2 set screws in the ferrule
    *pull the stub shaft out far enough to remove ferrule
    *pull the flex shaft from the rear of the boat.
    I grease as I would normally 2-3 runs.
